| Sponsors
| Our Forums | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | What have I done?!?! Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Well, I've finally gone and done it- I went crazy and ordered a butt-load of equipment for a fresh motor ...  | |
04-18-2009, 02:59 PM
| | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: Seattle
| | What have I done?!?! Well, I've finally gone and done it- I went crazy and ordered a butt-load of equipment for a fresh motor bike build. (My bike recently having been stolen, it was time to go for the gusto.)
So I ordered the following:
Gasbike.net 67cc Black Stallion Motor kit (Comes w biggie 2.5L tank)
Sick Bike Parts Standard Shift Kit (shifty gears!)
SBP Performance Air Filter (higher flow in)
SBP Expansion Chamber Exhaust Kit (back pressure and loudness!)
SBP Carb O-Ring (better carb seal on intake)
SBP 67cc Thin Head Gasket (increases Compression)
SBP High Efficiency Plug Wire (increases spark quality)
SBP Heavy Duty Front Freewheel (made by White Bros.)
SBP 11 Tooth Primary Drive Sprocket (increases top end)
SBP Fancy NGK Plug (better spark)
Manic Mechanic Clutch Actuator Kit (better feel, pulls from stops!)
SBP Engine Hardware Kit (grade 5 or better bolts for entire engine case)
Yeah, so that added up to quite the pretty penny! (Cool side note- we also ordered a Grubee motor for my one buddy and clutch kit for my other buddie's rigs at the same time!)
Now for the donor bike:
She's a 1984 Schwinn Sierra MTB. True Temper Chromoly frame, six speed rear freewheel, and O.G. "Bullmoose" handlebars. The bike is all original except for a retrofitted RST suspension fork. On this Pre-suspension Schwinn, a fork choppers out the HT angle a little for the worse, but that may equal out a bit with the added heft of the motor in-frame, and at speed, we'll see..
It's a quality old bike, in cream puff condition, and I believe the old school six speed rear freewheel and heavier gauge chain will be a perfect match for the SBP shift kit. My only qualm right now is I'm not in front of the bike at this moment and can suddenly not remember if it has a euro bottom bracket or an American one, and I'm just not positive if the SBP kit will come with what I need to set it up on either/or. I will worry about that when I get to it.
Anyhow, she's intended to be built up with a rear cargo rack and full coverage fenders, as well as knobby tires for some back roads/fire roads exploration. She'll be a spendy build when I'm done, but I figure why do this from scratch unless I can just do it up right?
Anyhow- there's my story! Can't wait to get my parts, I'll post pics of the donor bike tonight and when things start to arrive, update from there! What do you guys think about my little plan?
Cheers!
-Steve
__________________ www.firebellycycles.com
Visit me and my bikes at Sports X in Seattle, WA
1978 Vespa Grande, 1977 Mobylette 50L, 1980 Garelli VIP, 1959 Tote Gote Model B, 1961 Tule Trooper, 1963 Homelite Trail King, 1980 Yamaha XJ650 1985 Schwinn Sierra with 67cc/SBP Shift Kit/Pipe |
04-18-2009, 04:48 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jan 2009 Location: Phoenix, AZ
| | Re: What have I done?!?! Did you mention to Manic Mechanic that the Clutch Actuator Kit was going on a SBP kit? I seem to recall that he has a special one for the SBP kit.
I would have ordered the engine from someone else. Do an inventory when you get it and check for damage. Luckily you won't be using the muffler or chain guard, so you don't have to worry about them being dented and scratched.
Sounds like you are gonna have some fun.
Map your motorized bikes location on a Frappr Map show us where you are and post a pic of your bike. If trailer parks didn't exist would tornadoes exist?
04-18-2009, 05:39 PM
| | Re: What have I done?!?! I did NOT know there was a SBP compatible clutch kit- hmm.... I'll try emailing them to see if I can change the order. Hopefully they will get it before anything ships out on Monday. Thanks for that heads up I appreciate it!
Sounds like you've either had a bad experience with Gasbikes.net or know someone who has. I guess we'll see how they do...
04-18-2009, 05:47 PM
| | Re: What have I done?!?! Just emailed him, thanks again. Both SBP and Manic Mechanic are replying to emails today (good weekend service guys- THANKS!) so hopefully I'm in time to resolve a potential issue here..
04-18-2009, 06:43 PM
| | Re: What have I done?!?! Reply from James at Manic Mechanic received- change noted and shipping out Monday. SBP ships Monday too! Looking good for starting to build on Wednesday!
04-18-2009, 10:16 PM
| | Re: What have I done?!?! Quote:
Originally Posted by huckersteve I did NOT know there was a SBP compatible clutch kit- hmm.... I'll try emailing them to see if I can change the order. Hopefully they will get it before anything ships out on Monday. Thanks for that heads up I appreciate it!
Sounds like you've either had a bad experience with Gasbikes.net or know someone who has. I guess we'll see how they do... | Readin' these forums all the time I retain useless info, I guess the clutch thing is not useless, since I would need to know that if I bought one for the "Blue Bike".
I have purchased something from them and I sure hope the motor don't break before the warranty is up. I have not modified that engine at all. It is still as purchased. I am following all the break in procedures which should be completed in the next week or so. (You read it here folks so it must be true.) When I think of them I think of "Throw" And "Trust"
Map your motorized bikes location on a Frappr Map show us where you are and post a pic of your bike. If trailer parks didn't exist would tornadoes exist? |
04-18-2009, 10:25 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: Top of NY
| | Re: What have I done?!?! i ordered from gasbike.net and nothing was scratched or dented except my clutch cover had a couple of small tiny defect dings.my muffler is perfect paint and all.my chain guard is perfect too but its not on my bike yet.my engine is good too. |
04-18-2009, 10:47 PM
| | Re: What have I done?!?! Good to hear. I'm sure the motor will be fine
04-19-2009, 12:47 AM
Originally Posted by Cabinfever1977 i ordered from gasbike.net and nothing was scratched or dented except my clutch cover had a couple of small tiny defect dings.my muffler is perfect paint and all.my chain guard is perfect too but its not on my bike yet.my engine is good too. | I'm happy for you
04-19-2009, 08:15 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jun 2008 Location: memphis tn
| | Re: What have I done?!?! The only thing not on your list that would have to be on my list, if I had the money to do a build like that, would be one of Jim's motors that he is doing. You will see what I'm talking about from Jim's post here Transfer Port Modification- Pictures and results here.
Imagine that engine with your list of parts on that bike.
"I would rather be exposed to the inconveniences attending too much liberty than to those attending too small a degree of it." - Thomas Jefferson | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 11:06 AM. | | |
