What happened!
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. On my way to work today, Everything was running fine was about 2 miles from my destination. Suddenly my motor ...
Old 07-06-2009, 09:55 PM
Default What happened!
Everything was running fine was about 2 miles from my destination. Suddenly my motor dies without any warning.
On the weekend I was working on water proofing my bike. I had redone my wiring to make it warter proof so I think connection came loose I reconnected everything tonight, but I did not have time to test it.
Old 07-06-2009, 10:14 PM
deacon's Avatar
minor bike philosopher
Default Re: What happened!
if the wiring isnt the problem check to see if your fuel filter in the tank is plugged. It happened to be twice
Me and the Ebike
New Novel in progress blog...
Old 07-06-2009, 11:46 PM
Finfan's Avatar
To die that suddenly it does sound like the wiring. Especially since that is what you touched last. Usually a fuel filter will have it fussing and sputtering for a bit before it dies. If it isn't the wiring then your CDI might be suspect. If you can check to see if you have a spark.
-and-
I'm not lost, I'm exploring!
Old 07-07-2009, 12:53 AM
misteright1_99's Avatar
Possibly the spark plug wire came loose from the CDI or the Plug Cap.......
Old 07-07-2009, 01:56 AM
Junster's Avatar
Not trying to be a smarta$$ but did you run out of gas?
Put something FUN between your legs..
Old 07-12-2009, 01:32 PM
Ok gas is fine( gas (flow from the tank is the same as before), clutch seems tight, all wires are fine, I know my mix is good (Plug is brown) must be magnito or the coil< next i will have to test for spark
Old 07-12-2009, 01:52 PM
one las thing what is the best way to test for spark?????
Old 07-12-2009, 05:53 PM
Finfan's Avatar
Remove the spark plug and reconnect it to the wire.
Get your rear wheel off the ground somehow.
Hold the side of the plug against the engine block and turn the pedals by hand (be sure your other hand is not too close to the spark plug gap).
-and-
  #9 (permalink)
Old 07-12-2009, 09:16 PM
I think I found my real problem!
  #10 (permalink)
Old 07-12-2009, 10:17 PM
Creative Engineering's Avatar
MANIC Mechanic
Highly unlikely...see my post in your follow-up thread.
Jim
