| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | What do you use for anti-sieze? Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. So I have an old bike and the engine is in the mail. I've seen the tip to use ...  |
09-08-2008, 12:29 PM
|  | Motorized Bicycle Elite Member | | Join Date: Aug 2008 Location: Tucson, AZ USA
| | What do you use for anti-sieze? So I have an old bike and the engine is in the mail. I've seen the tip to use anti-sieze on the spark plug. What is it and where do you get it? I was at a motorcycle shop this weekend to get some synthetic 2-cycle oil and they had no idea what I was talking about.
Thanks!
-and-
I'm not lost, I'm exploring! |
09-08-2008, 12:40 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jul 2008 Location: WEST FRANKFORT, IL
| | Re: What do you use for anti-sieze? Quote:
Originally Posted by Finfan So I have an old bike and the engine is in the mail. I've seen the tip to use anti-sieze on the spark plug. What is it and where do you get it? I was at a motorcycle shop this weekend to get some synthetic 2-cycle oil and they had no idea what I was talking about.
Thanks! | FIRST OF ALL WHEN TWO DIFFERENT METALS LIKE THE DIFFERENT METALS IN THE SPARK PLUG AND ALUM/POTMETAL HEAD. OF THE ENGINE HEAT UP THE EXPAND AT DIFFERENT RATES AND CAN CAUSE THE PLUG TO BECOME IMPACTED IN THE HEAD AND MAKES IT HARD TO GET OUT WITHOUT STRIPPING THREADS ESPECIALLY IN ALUMINUM. ANTI SEIZE CAN BE PURCHASED AT YOUR LOCAL PARTS STORE . SOMETIMES ITS CALLED COPPER ANTISEIZE AND IT HELPS PREVENT METALS FROM BONDING TOGETHER INTHE CASE THAT YOU EVER WANT TO REMOVE IT IN THE FUTURE.
MEASURE ONCE AND CUT TWICE.......WAIT A MINUTE
09-08-2008, 01:39 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jun 2008 Location: Longmont, CO
| | Re: What do you use for anti-sieze? AutoZone. They oughta know what you're talking about, and they have it in little packets at the counter usually.
I can't believe the motorcycle shop didn't know about it, but they may not use aluminum-head motors much... |
09-08-2008, 01:59 PM
| | Re: What do you use for anti-sieze?  If I went into a shop and they had no ideal what anti-sieze is...I would turn around and exit as fast as possible and never return!! |
09-08-2008, 02:30 PM
| | Re: What do you use for anti-sieze? |
09-08-2008, 02:49 PM
| | Re: What do you use for anti-sieze? On a more serious note - you only need a little bit. I check my plug fairly frequently so I certainly only use it with a new plug.
I have Al paste, Copa slip, Nickel, - but the best for plugs? The little stick kind. It's Aluminum in semi solid "crayon" form. Not messy, easy to apply.
Again - too much or on the tip and you'll foul the plug I imagine. |
09-08-2008, 02:57 PM
|  | Motorized Bicycle Member | | Join Date: Aug 2008 Location: Deerfield, NH
| | Re: What do you use for anti-sieze? Copper Antisieze is cheaper but I use Aluminum Antisieze for its improved corrosion resistance. I ordered mine from McMaster-Carr along with enough threaded rod, bolts, washer, nets, gasket material, and a bunch of other stuff to set the engine up the way I wanted it. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 05:34 AM. | | | Sponsors
