Originally Posted by Bikeguy Joe I don't think you'll have any problems.
What kind of engine is it?
Can I ask why you want to change the plate? |
the engine is from a weed eater i bought about 12 years ago but never used.the only things i find are zama 14 on the carb,walbro on the ignition coil and walbro on the flywheel fan assembly.i want change the plate to trick out the engine a little,make it from aluminum plate, cut fins.it would change the case volume some so i thought i would ask to see if it would hurt the engine performance.thanks again bikeguy joe, you have a great website here.
