| Sponsors
| Our Forums | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Is the upgraded tensioner any better? Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Im getting a 80cc engine kit and it say upgraded tensioner with bearings is it any good?I also ordered a ...  | |
06-13-2009, 02:25 PM
| | Motorized Bicycle Member | | Join Date: Jun 2009 Location: Rhode Island
| | Is the upgraded tensioner any better? Im getting a 80cc engine kit and it say upgraded tensioner with bearings is it any good?I also ordered a spring one from tractor supply. |
06-13-2009, 04:09 PM
| | Motorized Bicycle Elite Member | | Join Date: May 2009 Location: usa
| | Re: Is the upgraded tensioner any better? spins easier, but the wheel on the TSC tensioner is way better.. |
06-13-2009, 04:12 PM
| | Motorized Bicycle Newbie | | Join Date: May 2009 Location: Maryland
| | Re: Is the upgraded tensioner any better? rimotorbiker, The spring tensioner from TSC is good, but you might find that you have to obtain a stronger spring. I had to modifiy my quite a bit to fit my bike, and just added a regular spring to pull from the back side. It worked well, and I eventually removed the roller and went to a sprocket which has been great. A lot of guys seem to be going to the t-shirt shims which make a lot of sense. I might try them on a second build. Good Luck |
06-13-2009, 04:29 PM
| | Motorized Bicycle Elite Member | | Join Date: May 2008
| | Re: Is the upgraded tensioner any better? I have a TSC wheel and spring and couldn't come up with an effective setup so I went bak to the original wheel. DAX kit came with wheel with a bearing it works fine. I may try to engineer a better mount for the TSC wheel/spring later on. |
06-13-2009, 07:34 PM
| | Re: Is the upgraded tensioner any better? can you use the tsc wheel on the stock tensioner mount matt? |
06-13-2009, 07:48 PM
|  | Motorized Bicycle Elite Member | | Join Date: Sep 2008 Location: Huntington, WV
| | Re: Is the upgraded tensioner any better? The stock mounting bracket for the tensioner can be used, with some modification. I used the stock bracket with the tractor supply tensioner and spring. I would think it could also be adapted for use in the location intended by the kit manufacturers. |
06-13-2009, 07:54 PM
| | Re: Is the upgraded tensioner any better? Have you had any problem with the chain hitting together that looks kinda close? |
06-13-2009, 08:03 PM
| | Re: Is the upgraded tensioner any better? Good eye, rimotorbiker. I do need to take another link out of the chain, as it does slap together sometimes. I haven't done it yet because I ordered a new clamshell adapter and sprocket from Creative Engineer. Have not installed it yet, though. I am thinking of getting a 36 tooth from Jim, I currently have a 34 tooth. |
06-13-2009, 08:09 PM
| | Re: Is the upgraded tensioner any better? Thanks for sharing the pic marvin im thinkin of ideas from it right now. |
06-13-2009, 08:14 PM
| | Re: Is the upgraded tensioner any better? No problem, that is what this forum is all about! I have been thinking about reversing the spring tension and letting the tensioner pull down on the bottom run of the chain. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 12:20 PM. | | |
