| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Tuning and 4-cycling Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Hello to all again. Got a couple questions for the 2-stroke educated. I know how they work but this ...  | |
10-23-2009, 01:05 PM
| | Motorized Bicycle Newbie | | Join Date: Sep 2009 Location: Florida
| | Tuning and 4-cycling Hello to all again. Got a couple questions for the 2-stroke educated. I know how they work but this 4cycling is a mystery to me. I have an 8 hp outboard 2 stroke that stutters at mid range rpm. Now that I have a cheap 2 smoke to tinker with, I now think it's 4 cycling. But so is my bike engine. At idle it runs good, with throttle open it runs perfect with power, at mid range just keeping it running it bucks and 4 cycles and jerks... open throttle it smooths out. How do I fix this?  |
10-23-2009, 01:12 PM
| | Motorized Bicycle Senior Member | | Join Date: Jan 2008 Location: England
| | Re: Tuning and 4-cycling Change the needle height in the carb, just experiment one notch either way
What do others think? |
10-23-2009, 01:15 PM
| | Re: Tuning and 4-cycling Well I did that last night, and I went up... Seemed to run worse. not really the 4cycle part, but just not top end, possibly starving for fuel. But thats what I didn't know. That carb pic post on here said stock was 2 from the top, well mine was 3 down from stock and I didn't know which direction made it richer/leaner. I have to go get some spark plugs today b/c the original is all black from break in. |
10-23-2009, 01:20 PM
| | Re: Tuning and 4-cycling If you put the C clip on the top notch, that will lower the needle & restrict the fuel flow a little, making it run leaner.
If you lower the clip, it will raise the needle allowing more fuel to flow!
Just look at the thing, & think about how it works...
Also... the needle doesn't do anything @ WOT; it only works in the mid-range area.
10-23-2009, 01:39 PM
| | Re: Tuning and 4-cycling ok that makes sense, but I thought it was the high speed needle, so why wont it effect WOT? what effects that, just the hole size in the jet itself? |
10-23-2009, 01:43 PM
| | Motorized Bicycle Elite Member | | Join Date: Jun 2009 Location: ny,ny
| | Re: Tuning and 4-cycling Quote:
Originally Posted by soccerrj88 ok that makes sense, but I thought it was the high speed needle, so why wont it effect WOT? what effects that, just the hole size in the jet itself? | Correct-a-mundo! |
10-23-2009, 01:47 PM
| | Re: Tuning and 4-cycling Give 'em the 'Malachi crunch'!!  |
| | Re: Tuning and 4-cycling So I opened the air intake a little by opening up the holes a little and cutting off the back of them. I also opened the baffle up, by uncrimping the two pipes comeing up. I should make it richer to componsate for this correct? |
10-23-2009, 01:49 PM
| | Re: Tuning and 4-cycling did you finish breaking in the engine yet? |
10-23-2009, 02:15 PM
| | Re: Tuning and 4-cycling Well I have about 170 miles on it and according to everyone on here, break in period is between 50 to 500 miles and anywhere from a 16:1 oil mix to 100:1 so I'm not quite sure. Right now, I'm using between a 18:1 to 24:1 mix. I put in 24 but add a little bit here and there to make sure it's oiled well because of the break in descrepancy. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 11:48 PM. | | | Sponsors
