Trouble shooting the bicycle engine that won't start
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. So here is a chance for all of us new guys to trouble shoot an engine that just doesn't ...
Old 02-21-2008, 09:53 AM
deacon's Avatar
Default Trouble shooting the bicycle engine that won't start
So here is a chance for all of us new guys to trouble shoot an engine that just doesn't start. So it has sat for a couple of weeks and been moved from one bike to another but it should still be the same things.
The engine rotates but doesn't start. It appears to be dead. It has compression since it won't roll freely.
So what is the next thing to check and how do i go about it.
I have checked the simple things... There is gas in the line. I have wired the black and green wire twice since it had to be rewired. I have disconnected the kill switch
Old 02-21-2008, 10:33 AM
deacon's Avatar
Default Re: Trouble shooting the engine that won't start
Okay I found mine in the wiring but, we still need this thread I think. What do you do first if one day your engine won't start.
Old 02-21-2008, 10:42 AM
CRUISER's Avatar
ADMINISTRATOR
first think i do is cuss
then i check for good spark
then getting gas
these 2 things are usually gonna be the reason for not starting
then i go to wireing etc
http://stockmarketcats.com/
Old 02-21-2008, 11:47 AM
deacon's Avatar
Okay but in detail how do you verify each of them
Old 02-21-2008, 04:10 PM
deacon's Avatar
I can see I'm gonna have to pull teeth... Okay suppose I couldn't get the engine to fire.
I check the fuel line and the fuel turn off switch and its okay.
So do I pull the spark plug to see if it's wet and smells of gasoline. Is that the easiest way to determine if there is gasoline getting to the cylinder.
So if the plug is wet go on if not check the carburator. (I tapped on the bottom of mine just in case the float was stuck by the way)
Old 02-21-2008, 05:59 PM
Bikeguy Joe's Avatar
I have only ever had a problem with the crappy kill switches that come with the kits....buy a momentary switch at you favorite electronics store to replace it asap.
Old 02-21-2008, 08:05 PM
deacon's Avatar
I use a toggle switch for an ignition type switch and kill. I expect you could use a key lock as well but the toggle works I hope for some kid trying to start it when I'm inside a store. I do sometimes not chain it down if I'm gonna be gone just a minute.
Old 02-21-2008, 09:48 PM
Norman's Avatar
LORD VADER Moderator
Not chaining it invites someone to take your bike a good chain and lock will slow down an honest thief.
norms-iron-works.tripod.com
  #9 (permalink)
Old 02-21-2008, 10:08 PM
deacon's Avatar
I know i'm a bad daddy for my bike... Good to see you back how was the vacation...
  #10 (permalink)
Old 02-22-2008, 06:09 AM
deacon's Avatar
Okay you got a wet stinky plug and its out of the head so now is the time to check the spark. Now I'm telling this from memory so don't be surprised if I get this wrong. Norman needs to tell it but he hasn't joined in yet so here goes.
take off the chain cover and get the rear wheel off the ground. with the plug wire near the head turn the engine over and look for a spark.
Now I think that is how he said to do it. I have never had to go that far yet.
I think that tells you that your electrical system is okay.
If you don't have spark, I would check out all the wiring. The kill switch, as well as the connections on the blue/green and the black ground from the engine magneto to the coil. There does not seem to be a lot to go wrong with the wiring, but I still managed to screw mine up.
I think if my plug was wet and stinky, and my spark was present I would think the spark plug itself was bad.
I have had cracked plugs in cars a few times so I wouldn't rule that out as many times as I have had to pull mine in this engine. I hope I don't have to pull it any more.
When I switched frames I installed the new plug and wire. It did seem to make the engine smoother but that is probably all in my head.
I'm sure if Norman weighs in he will improve this a lot.
Similar Threads
Won't start now!! Pablo Bicycle Engine Kits 26 05-07-2008 05:55 PM
Bicycle engine Paint troy994719 Paint Booth & Chop Shop 9 03-07-2008 09:04 PM
Motorized bicycle engine top end rebuild and an engine stand Norman Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 16 02-11-2008 06:40 AM
Troble shooting bicycle engine cdi and spark plug wire deacon Motorized Bicycle General Discussion 19 01-23-2008 09:58 PM
