| Sponsors
| | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | trouble with rear sprocket/chain Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. I've spent the better part of a day aligning the chain with the front and rear sprockets and making ...  | |
08-02-2008, 07:59 PM
| | Senior Motorized Bicycle Builder | | Join Date: Jul 2008
| | trouble with rear sprocket/chain I've spent the better part of a day aligning the chain with the front and rear sprockets and making sure the chain isn't rubbing on the frame or tire. But, the chain doesn't seem to want to mesh smoothly with the rear sprocket. It keeps binding up and coming off the sprocket. It makes a lot of noise even when it does manage to stay on for a while. Any hints as to how to smooth it out? |
08-02-2008, 08:23 PM
| | Re: trouble with rear sprocket/chain See if the tips of the teeth are catching the chain. Some older kits had this problem. The way around it is to take the rear sprocket off and file or dremel the edges of the teeth off. Not a big deal.
08-02-2008, 09:18 PM
| | Re: trouble with rear sprocket/chain Quote:
Originally Posted by Bikeguy Joe See if the tips of the teeth are catching the chain. Some older kits had this problem. The way around it is to take the rear sprocket off and file or dremel the edges of the teeth off. Not a big deal. | Not sure what you mean. Is catching the chain a good thing or a bad thing? File the edges of the teeth so they are narrower? |
08-02-2008, 10:28 PM
| | Master Motorized Bicycle Builder | | Join Date: Jun 2008 Location: memphis tn
Originally Posted by brucemg51 Not sure what you mean. Is catching the chain a good thing or a bad thing? File the edges of the teeth so they are narrower? | yeah, just knock the square edges of the teeth off, on both side, and this will allow the chain to meet the sprocket better
good luck
Let the solution BE the revolution
08-02-2008, 11:18 PM
|  | Master Motorized Bicycle Builder | | Join Date: Jun 2008 Location: Longmont, CO
| | Re: trouble with rear sprocket/chain Here's one thing I noticed today. If your rear chainstay is angled outwards as it goes back towards the wheel, you may have issues. The tensioner will be at the same angle of the chainstay, and this makes the chain run at an angle across the tensioner wheel. If you adjust it so it's quiet, it takes the chain off the sprocket.
One solution would be to "twist" the bracket. I tried to do it with a couple pair of pliers today but failed. Need to figure out a good way to do it. |
08-03-2008, 12:36 AM
|  | Manufacturer/Dealer | | Join Date: Dec 2007 Location: Charlottesville, VA
| | Re: trouble with rear sprocket/chain HI jasonh,
To bend the tensioner bracket it really helps to have a table mounted vise and a large pipe wrench and/or a small sledge hammer....Pliers may work but you'd probably have to look like Rambo to do it using that ;-)
Hope this helps you....Good luck!
Andrew
PS - 2 pipe wrenches may work tho....just need the longer ones for more leverage.... |
08-03-2008, 07:51 AM
Originally Posted by jasonh Here's one thing I noticed today. If your rear chainstay is angled outwards as it goes back towards the wheel, you may have issues. The tensioner will be at the same angle of the chainstay, and this makes the chain run at an angle across the tensioner wheel. If you adjust it so it's quiet, it takes the chain off the sprocket.
I "adjust" mine with a pair of 18" channel lock pliers.
08-03-2008, 08:41 AM
One solution would be to "twist" the bracket. I tried to do it with a couple pair of pliers today but failed. Need to figure out a good way to do it. | What is "rear chainstay"? Is this different from the tensioner? Am I missing something? |
08-03-2008, 09:48 AM
| | Re: trouble with rear sprocket/chain Hi,
The rear chain stay is the piece of the frame that you typically mount the chain tensioner on....It is the tube that runs parallel to the ground from the bottom bracket to where the rear wheel attaches to the frame.
Hope this helps
Andrew |
08-03-2008, 09:52 AM
Hope this helps
Andrew | Thanks. Being an old motorcycle mechanic, I would think of that piece as the swingarm, although the term doesn't really apply to a bicycle. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 11:19 AM. | | |
