Tips on Starting your Shift-Kit equiped bike
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. ok, PLEASE give all the tips on starting this shift-kit equipped beast...its like pedaling a tank!...
Old 07-10-2009, 03:00 PM
MrLarkins's Avatar
HS Math Teacher
Default Tips on Starting your Shift-Kit equiped bike
Old 07-10-2009, 03:06 PM
Clotho's Avatar
Default Re: Tips on Starting your Shift-Kit equiped bike
Choke on if the engine is cold. Prime it if it is cold. Bike in lowest gear. Point bike downhill. Right pedal at the top of the arc (I'm right handed). Clutch out. Stand up on the pedal gently and it should start.
__________________________________
Find out about my latest bike project at: Tribridbike.com
Old 07-10-2009, 03:14 PM
MrLarkins's Avatar
HS Math Teacher
like a kick start almost, right?
Old 07-10-2009, 03:28 PM
Ghost0's Avatar
Not like a kick start, as Clotho said get the pedal of your strong leg just past the top of the crank arc. Apply your weight to it and it should start to turn over. Once it starts to turn over just keep pedaling. It also helps to get the bike moving at a decent pace so you are just turning the engine over and trying to propel the bike at the same time.
www.sickbikeparts.com
Old 07-10-2009, 10:23 PM
lordoflightaz's Avatar
Like Ghost sez, except if I don't get it to pop I rewind back up and step down again, that way I don't have to pull in the clutch to get it back to just past the top of the arc. Latest build I think my clutch might be a little loose so I can pedal it through but will be tightening that up. I do it on the weak side leg, right, makes it easier to give it some gas.
Map your motorized bikes location on a Frappr Map show us where you are and post a pic of your bike.
If trailer parks didn't exist would tornadoes exist?
Old 07-10-2009, 10:25 PM
joewlms3's Avatar
if the rear wheel didnt have a freewheel would it be able to then bump start?
Old 07-10-2009, 10:58 PM
Creative Engineering's Avatar
MANIC Mechanic
MrLarkins,
It's the change that is hard to get used to. We form habits that are hard to break. Once you get out of the mind-set of "pedal-stop pedaling-release clutch-Go"; it's not so bad.
Brett Mavriks' jack-shaft set-up was the same way...it was VERY awkward at first. As suggested, pedal up to 5-7MPH before releasing the clutch, (the momentum will help), and then continue to pedal hard against the compression of the engine until it starts.
Get the engine fine tuned, and learn exactly what it takes to execute an easy start as Clotho pointed out.
Before long it will be second nature.
Jim
Old 07-10-2009, 11:08 PM
MANIC Mechanic
YES...and for the remainder of the ride you will be aboard a traveling egg, I mean leg, beater.
Jim
  #9 (permalink)
Old 07-11-2009, 04:23 AM
Clotho's Avatar
Alas no, The freewheel is on the pedal crank so same difference. The motor won't turn over unless you are turning it over. You are already pedaling downhill right? Giver a little gas and she goes! Become one with the machine.. No need to kick the machine... Just make it turn over a few times.
  #10 (permalink)
Old 07-11-2009, 07:57 AM
MrLarkins's Avatar
HS Math Teacher
good suggestions guys, any more?
