| Sponsors
| | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | ThatsDax "65"cc Head Bolt Torque Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Hello there fellows.
Anyone got the spec?
Thanks....  |
07-11-2008, 07:06 PM
|  | Motorized Bicycle Builder | | Join Date: May 2008
| | ThatsDax "65"cc Head Bolt Torque Hello there fellows.
Thanks.
__________________ |
07-11-2008, 07:33 PM
| | Re: ThatsDax "65"cc Head Bolt Torque 15 ft. lbs. should do it.
07-11-2008, 07:39 PM
| | Re: ThatsDax "65"cc Head Bolt Torque slowly approached criss cross applesauce......... |
07-11-2008, 11:14 PM
| | Re: ThatsDax "65"cc Head Bolt Torque 15 ft/lbs aint much.
Is that from DAX, or is it just from general experience?
I have em at 15. Unless I think I'm taking a compression hit, I'll probably keep them there. Just hope nothing rattles-off.
07-11-2008, 11:51 PM
| | Master Motorized Bicycle Builder | | Join Date: Feb 2008
| | Re: ThatsDax "65"cc Head Bolt Torque 12-15lbs may do it for the 65. Not sure, I always go by feel. but You are right, it is not much, but the 65 has the smaller 6mm cylinder studs. So.. You do not want to over tighten and rip them through. . Tighten them by feel, run it and warm it up real good. Park it, let it cool overnight and then tighten them a little more. Check for leaks with carb cleaner. And remember, 6mm can not take much torque. I go by feel. Run it, let it cool, and then torque them a little more after it cools. Enjoy the ride...
07-12-2008, 12:35 AM
| | Re: ThatsDax "65"cc Head Bolt Torque Quote:
I have em at 15. Unless I think I'm taking a compression hit, I'll probably keep them there. Just hope nothing rattles-off. | Do you have the 6mm or 8mm studs.....?
15 ft/lbs is plenty for 8mm and may snap 6mm studs.
Also if you have those cheezy acorn nuts, I suggest you lose them and get some real nuts. |
07-12-2008, 07:31 AM
| | Re: ThatsDax "65"cc Head Bolt Torque I have my 8mm @ 25 ft.lbs....
If you don't have a torque wrench, grab the handle of your ratchet all the way up by the ratchet part and tighten firmly...that will get you close to 15 lbs.
07-12-2008, 08:08 AM
| | Re: ThatsDax "65"cc Head Bolt Torque I'll bet you don't have acorn nuts  stock studs? | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 11:17 AM. | | |
