Tensioner Redux
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. My stock tensioner broke so I'm giving this a try. The roller is from Tractor Supply and has been ...
Old 11-04-2009, 09:35 PM
stilldoc's Avatar
Default Tensioner Redux
My stock tensioner broke so I'm giving this a try. The roller is from Tractor Supply and has been discussed on this forum but mounted on the seat post.
I'm using it bolted down, but it could also be configured to swing loose and attach to a spring.
Once I'm satisfied with the position, I will anchor the bracket to the chain stay with a self tapping screw to prevent rotation into the spokes.
(Looking at the photo while previewing this message, I think I might try facing it the other way, toward the back wheel, to get the bolt heads away from the chain)
Old 11-05-2009, 11:22 PM
stilldoc's Avatar
Default Re: Tensioner Redux
Okay. Don't try this as it's pictured above. The roller bracket metal is not strong enough to withstand the torque created when starting the bike. Mine wound up like this:
I'm lucky it didn't rotate into the spokes.
Old 11-05-2009, 11:32 PM
2door's Avatar
People underestimate the pressure applied to the chain under load; which is why so many have had the tensioner bracket come loose and be pulled inward, into the spokes. I've never tested the force on the chain at that point but it would be an interesting figure to know so we could pass along that information to new builders. Keep us informed on how your bracket idea is working. I'm glad the bracket is all that was damaged with your experiment. Thanks for sharing the photos.
Over Youth and Skill
Old 11-06-2009, 05:05 AM
BarelyAWake's Avatar
I just wanted to say thanks for the follow up on this 'un - it's helpful to hear the problems as well as potential "solutions" and far too many of us forget to mention when somethin' goes south.
Looks like it's still a good 'un tho, if with just a stronger plate and/or a spring... you gonna mess around w/it more? If so - keep us posted
Old 11-06-2009, 10:23 AM
stilldoc's Avatar
I like the bearing roller. It's smooth and quiet, so I think I'm going to try to find a way to attach it directly to the stock tensioner bracket with a grade 8 bolt. What I'm trying to accomplish is to develop a solution that doesn't require welding (since I don't have a welder) and uses easily acquired parts.
Old 11-06-2009, 10:42 AM
I agree - the bearing roller upgrade was a significant improvement on my bike
Jus' a FYI for those less inclined to DIY, Spooky and Dax both sell a replacement roller with a bearing (as I'm sure others do too) in case yer kit came with the older style w/o a bearing;
ThatsDax - Bearing Chain Tensioner
Spooky Tooth Cycles - Cartridge Bearing Chain Tensioner Wheel
Old 11-06-2009, 10:58 AM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Most engine kits these days have the good bearing rollers in them!
Old 11-07-2009, 12:45 AM
stilldoc's Avatar
Here's the latest rendition. It requires a 6mm bolt, a spacer, and washers.
Holding so far. I'll update the thread if it fails.
  #9 (permalink)
Old 11-07-2009, 06:05 PM
stilldoc's Avatar
Holding up so far. Several startups and rode about 25 miles today.
  #10 (permalink)
Old 11-07-2009, 06:18 PM
2door's Avatar
Glad to hear it. Thanks for keeping us updated. Use caution however. You've already seen what can happen so keep a close watch on the bracket and make sure it doesn't move on the chainstay. You don't want all that steel to get pulled into your spokes.
I see a small hole in the stay. Is that from an earlier mount?
