take a tip...leave a tip
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Xlite in air planes dont you pray 1st also and give offerings to MURPHY so you dont crash?...
LinkBack (14) Thread Tools Display Modes
  #251 (permalink)
Old 10-06-2009, 12:39 PM
Default Re: take a tip...leave a tip
  #252 (permalink)
Old 10-06-2009, 12:42 PM
BarelyAWake's Avatar
Murphy will not be amused by your heathen talk.
|.o
  #253 (permalink)
Old 10-06-2009, 01:13 PM
I've rode my bike 3 times now without a helmet and without a pin to ensure my chain tensioner doesn't rotate into my spokes. I'm really asking for it.
I better get a helmet after work.
  #254 (permalink)
Old 10-06-2009, 01:24 PM
Don't know about Murphy but prayer may not be best option with planes, bikes, or specially medical operations according to American Heart Journal:
Elsevier
  #255 (permalink)
Old 10-18-2009, 01:55 AM
Tcams_Zonie's Avatar
So much good info It is defiantly worth the time to copy/paste into a doc. Thanks Bikeguy Joe for your words of advise. I will be using them a lot.
  #256 (permalink)
Old 10-18-2009, 08:27 AM
Earthman's Avatar
Originally Posted by rfriesen View Post
xlite again! I agree. Not giving up too soon is great but why should replacing something that's probably not working be refered to as giving up? Replace the magneto is something I've read again and again on this site. I replaced it and my bike worked instantly.
With all due respect, if you didn't check the mag winding with a meter, but replacing it "fixed your problem," you may have just had a bad connection, which went away as a result of going through the motions of replacing the mag. I'm sure this sort of thing has happened to me at least a few times in my life. In any case, it's good your MB is running again!
  #257 (permalink)
Old 11-10-2009, 12:21 AM
wjliebhauser's Avatar
All good stuff, and many items I had to figure out on my own! The chain master link is a sore point with me. They are pretty flimsy and not hard to make them fail. When mine flew off, the rest of the master link was ok. So waiting for a new one, I took some high-tensil fine wire, like old 'piano wire' or such, did a figure-8 into the grooves of the link pins and twisted it off, cut, and pounded the 'rattail' flat agains the link. Been ruuning for months, never comes loose, and I never installed the new master link keeper...
  #258 (permalink)
Old 11-10-2009, 12:30 AM
bairdco's Avatar
yikes. i guess, if it works for you, great. but i'd recommend getting a chain breaker and getting rid of your masterlink altogether. that's one place i wouldn't want a failure.
  #259 (permalink)
Old 11-10-2009, 01:48 PM
Hello! New Rider< I Have A 48cc Grubee That Is Broke In And Now It Seems To Be Un-able To Run Wide Open ...ie. I Have To Mess With The Choke To Get Her Up2speed It Will Run Good For Awhile Then I Gotta Mess With Choke To Keep Speed Up. Any Help Would Be Awsome Plz&thz.
  #260 (permalink)
Old 11-10-2009, 08:19 PM
Check for air leak between carb and cylinder, or restricted gas flow. Should be one or the other. An 'o' ring where the intake tube joins into the carb heps seal it, make sure its is big enough to be snug in the carb and won't get sucked into the intake tube. Tighten the clamp tight. If gas flows easily/fully to carb, check for dirt in bowl or float not swinging smooth. Other more exotic possibilities, but try those first!
"Captain Easy"
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f3/take-tip-leave-tip-121.html
Posted By For Type Date
Wear your helmet!!!!!!!!!!!!!!!!!!!!!!!! - Stlbiking Message Board - Page 2 This thread Refback 10-05-2009 05:02 PM
Always wear a helmet - Stlbiking Message Board This thread Refback 12-19-2008 05:30 PM
Always wear a helmet - Stlbiking Message Board This thread Refback 12-19-2008 12:48 AM
Always wear a helmet - Stlbiking Message Board This thread Refback 12-18-2008 11:01 PM
Always wear a helmet - Stlbiking Message Board This thread Refback 12-18-2008 10:59 PM
Always wear a helmet - Stlbiking Message Board This thread Refback 12-18-2008 10:41 PM
Wear a helmet.... - Bob Is The Oil Guy This thread Refback 12-12-2008 11:57 PM
Wear a helmet.... - Bob Is The Oil Guy This thread Refback 12-05-2008 12:45 PM
Wear a helmet.... - Bob Is The Oil Guy This thread Refback 12-05-2008 11:33 AM
Wear a helmet.... - Bob Is The Oil Guy This thread Refback 12-05-2008 11:07 AM
Wear a helmet.... - Bob Is The Oil Guy This thread Refback 12-05-2008 09:17 AM
Wear a helmet.... - Bob Is The Oil Guy This thread Refback 12-05-2008 08:48 AM
Wear a helmet.... - Bob Is The Oil Guy This thread Refback 12-05-2008 12:17 AM
Wear a helmet.... - Bob Is The Oil Guy This thread Refback 12-05-2008 12:04 AM
