| Sponsors
| | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | take a tip...leave a tip Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Never kiss a girl with a high fever (from my dad when I left home)...  | |
10-01-2008, 10:16 PM
| | Re: take a tip...leave a tip Never kiss a girl with a high fever (from my dad when I left home) |
10-01-2008, 10:58 PM
|  | Master Motorized Bicycle Builder | | Join Date: Aug 2008 Location: Monrovia,CA
| | Re: take a tip...leave a tip never use a 415 chain on a 41 sprocket, your bike will lock up on you as soon as the chain warms up
People say that if you play Microsoft CD's backwards, you hear satanic things, but that's nothing, because if you play them forwards, they install Windows. |
10-28-2008, 02:33 PM
| | Motorized Bicycle Apprentice | | Join Date: Oct 2008 Location: west texas
| | Re: take a tip...leave a tip yea Decon my throttle was horrible.I did my throttle, put a set of harley grips on. I used innertube and electical tabe to increase the size. I had to send my engine back cause it had a blown head gasket but when I get it back it should be good. Any idea's for a bike issue I need like a fork lock I have ape hangers and they hit the tank I need to have forks lock so they don't go all the way around. I have pic's but haven't figured out how to post them on here. Any suggestions welcome.
Biker Dave
11-09-2008, 06:45 PM
|  | Motorized Bicycle Builder | | Join Date: Oct 2008 Location: New York
| | Re: take a tip...leave a tip i've gleaned so much from this forum its time i can hopefully give something back! It seems that every bike i mount an engine on to needs to have the carb moved, so the first one i spent hours on welding up a steel manifold. it worked well but took to much time to make it look presentable. However you can get a copper street 45 deg elbow in 5/8". It seems this size (5/8)is used for central air conditioning systems and any good supply house will have them. the stock clamps work fine its a perfect fit on both ends and if you need to make it longer just solder on another piece (or silver solder if your worried about temp) i took some temp readings of the manifold after riding hard for about 10 mins and could not get it over 100 degs so for me regular plumbing solder works just fine. if i can get my camera up ill post a pic. Hope this helps someone out. Thanks guys your great, Joe |
11-09-2008, 06:51 PM
| | Re: take a tip...leave a tip the other thing i failed to mention was instead of heating and bending exhaust pipes to clear the frame, try cutting a shim using the exhaust manifold as a template, use aluminum flat stock 1/4" thick then after youve drilled the holes and shaped it place it face down on a belt sander and taper it as much as u need to. then reinstall with two gaskets. Joe |
11-09-2008, 06:52 PM
| | Re: take a tip...leave a tip Oh and watch your fingers on the sander!!!! |
11-15-2008, 07:16 AM
| | Motorized Bicycle Apprentice | | Join Date: Nov 2008 Location: Hawthorne CA
| | Re: take a tip...leave a tip Lots of parts that we want such as extra gas tanks, fuel system parts, etc can be gotten at go kart sites. I have plastic and metal tanks plus components at www.gokartracing.com, there are others out there too. When stumped for parts I usually go search there. |
11-18-2008, 05:42 PM
| | Master Motorized Bicycle Builder | | Join Date: Jul 2008 Location: Northglenn,Colorado
| | Re: take a tip...leave a tip I got a great tip here thought I would share. How to Stud your Tires for the Winter
1) Go To Wal Marts
2) Bring Money.
__________________ You have found the fountain of youth. Ride and forever stay young. |
11-18-2008, 07:13 PM
|  | Senior Motorized Bicycle Builder | | Join Date: Aug 2008 Location: Houston
| | Re: take a tip...leave a tip I can see I need to make a check list, or build a assemby note book. There is so many things I want to do on my next build from all the ideas here. I know I will forget a step and as in the past have to duplicate so many steps like pulling the motor out over and over. |
11-18-2008, 07:28 PM
| | Re: take a tip...leave a tip found a site that can supply anything we might ever need! Industrial Supply Equipment from MSC Industrial Supply, from threaded rods to you name it, order their catalog, its over fourteen hundred pages of great stuff! and shipping is fast! | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 11:33 AM. | | |
