Stalling out
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. When I disengage the clutch, the motor stops..no idling. Otherwise, it works fine. What's happening?...
Old 09-20-2009, 09:11 PM
Default Stalling out
Old 09-20-2009, 09:40 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Default Re: Stalling out
I had this problem on one of my bikes... I had the clutch cable & CDI wires zip tied to the frame, & when I pulled the lever it was messing with the wires.
Cut off the plug ins & solder & heat shrink the wires!
Old 09-20-2009, 09:57 PM
2door's Avatar
I know this sounds like a simple fix and please don't take offence but have you tried turning the idle screw in a little? In= higher idle speed, out= lower. The idle screw is the one with the spring and screwdriver slot on the left side of your carburetor. It engages the throttle slide and allows or prevents movement past a certain point depending on how far it is screwed in.
Over Youth and Skill
Old 09-24-2009, 09:39 PM
Thanks... I knew the screw adjusts the speed but I didn't know which way does what. I will try this.
