Sprocket size????
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. The OP was talking about a frame mount chain drive model....
  #11 (permalink)
Old 06-06-2008, 08:45 AM
Bikeguy Joe's Avatar
MODERATOR
Default Re: Sprocket size????
  #12 (permalink)
Old 06-06-2008, 08:47 AM
MODERATOR
Anyhow- to the OP- A different sprocket is not required or needed, unless she is going out for a high top speed or loooong cross country cruises, then it will be a help, but still not a requirement.
  #13 (permalink)
Old 06-06-2008, 08:50 AM
cityevader's Avatar
Originally Posted by Easy Rider View Post
My mistake. I didn't read the whole thread. I thought the discussion was about sprockets. You are correct that on friction drives, the diameter of the spindle determines the speed.
You're right too! It started out as a sprocket question, and somehow I ping-ponged into friction drive...my fault!
HoughMade's response says it all.
But I might suggest using whatever sprocet the kit comes with, so you don't go spending money before you even know what you like. If after engine break-in, you want more torque and willing to tade off top speed, then go bigger sprocket. If torque takes a back seat to top speed, get a smaller sprocket. But base it on what like/want from experience.
  #14 (permalink)
Old 06-06-2008, 09:00 AM
Shouldn't be a problem with the 24" wheels. Just going to be slower and a little more trque. If a person is larger this set up is ideal.
Advertisers
