| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Springer Front End Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Any One Have Any Problems With The Schwinn Type Springer Front End?
I Found Springer Front Ends As Cheap As $...  |
08-18-2009, 06:38 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jun 2009 Location: jacksonville NC
| | Springer Front End Any One Have Any Problems With The Schwinn Type Springer Front End?
I Found Springer Front Ends As Cheap As $29.99. Will It Hold Up? |
08-18-2009, 10:11 PM
|  | Motorized Bicycle Elite Member | | Join Date: Sep 2008 Location: AZ now, TX in 2010
| | Re: Springer Front End Should hold up unless you plan to ride MTB trails.
"Don't believe everything you read on the internet. That's how World War I got started" - PS3 commercial |
08-18-2009, 10:17 PM
| | Re: Springer Front End You'll probably want to tighten all the bolts extra tight!!! They're kinda "wobbly" feeling! |
08-18-2009, 10:42 PM
|  | MB Builder Extraordinaire | | Join Date: Jul 2008 Location: coventry, RI
| | Re: Springer Front End if i may make a helpful suggestion....
my cop bike's springer bolt flew out of the assembly as i was tooling down the road, causing quite the wobbly side-to-side action.
i remedied this by gooping some jb-weld at the very end of the bolt (shown in blue).
i loosened that bolt until it a couple threads cleared the backside. that way i get the most suspension from it. if you tighten the crap out of the main bolt, it'll compress the spring and be as stiff of a ride as though it wasnt there. defeating the purpose.
__________________ New, fully assembled motored bikes here: http://happytimecycles.wordpress.com/ 401-952-7064 Quote:
Originally Posted by Dan sn0rk. | Quote:
Originally Posted by Bikeguy Joe You are one sick man spun, I like that quality in a person. | A 20-year smoker, I quit smoking with the help of this--->http://www.premiumecigarette.com/415.html a smokeless, non-tobacco electronic cigarette.
08-18-2009, 11:13 PM
|  | Motorized Bicycle Elite Member | | Join Date: Apr 2008 Location: Valparaiso, IN
| | Re: Springer Front End Here's what I did with the springer- blue loctite on the pivot bolt and the small bolts holding the top of the arms to the saddle.
For the big center bolt, I screwed the bolt in far enough to put a jam nut on the other side of the plate- it's not tpp tight, but it kicks the front end out nicely. I used blue loctite on that too and tightened the jam nut on there tight. I have never had to tighten any of them since- almost 2 years on that setup.
08-18-2009, 11:15 PM
| | Motorized Bicycle Newbie | | Join Date: Aug 2009 Location: VA
| | Re: Springer Front End If I may ask, where did you find the front end?
Thanks |
08-19-2009, 12:11 AM
| | Re: Springer Front End |
08-19-2009, 12:56 AM
| | Re: Springer Front End Thank you very much! | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 03:36 PM. | | | Sponsors
