| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Speedometer problem from RFI or EMI. Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. I just installed a cheap, 4-function electronic bike speedometer that mounts to the handlebars of my bike (I wanted ...  |
04-05-2009, 02:58 PM
|  | Motorized Bicycle Senior Member | | Join Date: Mar 2009 Location: Pittsburgh, PA
| | Speedometer problem from RFI or EMI. I just installed a cheap, 4-function electronic bike speedometer that mounts to the handlebars of my bike (I wanted to know how fast I was going). After setting up the meter and starting the engine, I found that electronic noise from the ignition system caused the new meter to malfunction by going into reset mode. As long as the engine was running, the meter would not work.
The fix was to install a small split ferrite bead on the sensor wire between the magnetic sensor and the meter (see photos). These things are made to suppress RFI (radio frequency interference) in electronic equipment. They are inexpensive and easy to install. I just happened to have a bunch handy, snapped one on, and solved the problem. Since I’m an amateur radio operator, a.k.a. HAM, I tend to accumulate such stuff.
If you have similar problems, but don’t have a split ferrite bead handy and don’t know a HAM, you might be able to find one at Radioshack or online. Buy from the following links: Digi-Key - 240-2344-ND (Steward - 28A0434-0A2)
The link above is for Digi-Key Part Number240-2344-ND 0431164281 Beads
More info on RFI suppression can be found at … Ferrite Beads
04-05-2009, 03:13 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: upstate NY
| | Re: Speedometer problem from RFI or EMI. thanks thats the problem im having. |
04-06-2009, 02:17 AM
| | Motorized Bicycle Elite Member | | Join Date: Feb 2008 Location: Newcastle
| | Re: Speedometer problem from RFI or EMI. Also the battery can vibrate off its terminals causing a reset. Some soft rubber packing helps it stay in place. |
04-06-2009, 10:22 AM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2008 Location: Bellingham, WA
| | Re: Speedometer problem from RFI or EMI. I prefer to fix the problem rather than adding a band aid, although the band aid works. If you replace your plug wire and boot with a good one it will solve the problem as well and it really should be done anyway since the stock plug wire and boot are pretty crappy. |
04-06-2009, 10:16 PM
| | Re: Speedometer problem from RFI or EMI. I don't know if my meter has a plug wire and boot - it's all hardwired together. Replacing the stock light-gauge zip cord with coaxial microphone cable may help, but it only took about 10 sec. to put the split ferrite bead on, and it didn't cost me anything 'cause I already had the part. |
04-07-2009, 11:24 AM
|  | Motorized Bicycle Elite Member | | Join Date: Feb 2009 Location: Arroyo Grande, Ca
| | Re: Speedometer problem from RFI or EMI. Quote:
Originally Posted by Earthman I don't know if my meter has a plug wire and boot - it's all hardwired together. Replacing the stock light-gauge zip cord with coaxial microphone cable may help, but it only took about 10 sec. to put the split ferrite bead on, and it didn't cost me anything 'cause I already had the part. | I believe he is talking about the motor plug wire and boot, sick bike parts has some, worked great to fix the resetting of my speed o. I still get some interference from the cdi and kill switch being so close to the speed o. The speed o doesn't reset, but the mph tend to jump around, but not enough to not see how fast I'm going most times.
__________________ Sun Tzu: To secure ourselves against defeat lies in our own hands, but the opportunity of defeating the enemy is provided by the enemy himself. |
04-07-2009, 05:06 PM
| | Re: Speedometer problem from RFI or EMI. Thanks for clearing that up (I'm a newbie when it comes to these motors). I agree that a better plug wire and boot can make a difference. However, a ferrite bead will block RFI and EMI from entering the electronic device along external wires, which act like antennas. Try it, it may fix your intermittent problem. |
04-07-2009, 08:32 PM
|  | Motorized Bicycle Senior Member | | Join Date: Feb 2009 Location: Fresno CA USA
| | Re: Speedometer problem from RFI or EMI. You can go to a auto parts store and get a good 7mm coil wire with boots on both ends and cut in half and now you have two plug wires for your motor. I was having the same problem with my speedo and this solved my problem. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:26 PM. | | | Sponsors
