Which sparkplug?
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. What plugs are used in these in frame china girls? I know everybody says NGK B6HS. My real question is ...
Old 03-03-2009, 02:15 PM
Default Which sparkplug?
What plugs are used in these in frame china girls? I know everybody says NGK B6HS. My real question is what are equivelents ( Heat range too ) in Champion,Autolite,Bocsh etc. if there are any. Thanks
Old 03-03-2009, 02:29 PM
Bikeguy Joe's Avatar
Default Re: Which sparkplug?
SPARK PLUG CROSS REFERENCE
About 3/4 of the way down you'll see the B5HS plug and all it's replacements...
Old 03-03-2009, 02:40 PM
junkyard's Avatar
Spark Plugs | Automotive Spark Plug | Motorcycle Spark Plugs | E3
this is the plug i got E3.12
kicks right over.....i kickstart my bike using the pedal....not while im moving......lift rear wheel and kick
i didnt even gap it....lol
might run hot tho.....Spark Plugs | Automotive Spark Plug | Motorcycle Spark Plugs | Small Engine Sparkplugs | Automobile Spark Plug for Cars or Trucks
Old 03-03-2009, 04:21 PM
Got to love computers, Bikeguy says look below 3/4 way down, there is one other post about e5-12 withh a sparkplug website but I could not open it except for the home page
Old 03-03-2009, 04:56 PM
Pablo's Avatar
We say just stick with NGK. Low cost, best, least prone to foul. You really might want to try NGK BP6HS. "P" is extended electrode.
Scroll for NGK plugs
Old 03-03-2009, 05:05 PM
brisbane_boy's Avatar
thanks for that info pablo. I was going to get a B6hs but i might see if they hav a BP6HS.
Just a question what does an extended electrode actully do???
Thanks
BB
who needs a car wen u can have a motor bicycle
Old 03-03-2009, 08:43 PM
Pablo's Avatar
Thanks
BB
Per our web page:
NGK BP6HS.....with an extended tip, it centers the spark in the combustion chamber and actually displaces volume, effectively increasing compression ratio. An added benefit is with the protruding electrode the plug is even more foul proof than the standard B6HS. Also, the 6 is a cooler heat range for those hard max throttle runs.
Also in the "5" heat range.
NGK BP5HS.....with an extended tip, it centers the spark in the combustion chamber and actually displaces volume, effectively increasing compression ratio. An added benefit is with the protruding electrode the plug is even more foul proof than the standard B5HS. Also, the 5 is a hotter heat range plug for those colder days.
It's a LOT better in the fouling department, and you just might feel a little power. Tiny difference but with a single cylinder so dependent on the plug, using the best plug is something we see as important.
Old 03-03-2009, 11:10 PM
NunyaBidness's Avatar
Didn't we have a post about some one using a different plug and it stuck down into the chamber a little too far with the result of the piston head hitting it?
I know my memory doesn't work very well at times but I'm pretty sure I read something like that somewhere.
  #9 (permalink)
Old 03-04-2009, 06:11 AM
Pablo's Avatar
It could happen is someone used the wrong plug.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70
