| Sponsors
| | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Spark knock Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. You say anti rotation pin I say ..... never mind...  | |
05-17-2008, 08:49 PM
| | Re: Spark knock You say anti rotation pin I say ..... never mind |
05-20-2008, 09:41 PM
| | Re: Spark knock I like tits too
05-21-2008, 10:59 AM
| | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Daytona Beach
| | Re: Spark knock Where can I get one of these bushings, so I can have it ready before I even put the engine back together. I guess needle bearings are going to be out of the question since they are probably not going to fit. |
05-21-2008, 03:16 PM
|  | Genius Visionary | | Join Date: Jan 2008 Location: Ashtabula county, Ohio
| | Re: Spark knock Contact the original seller of your engine kit and ask if they can get the parts you are looking for.
No, a bearing will not retrofit where the bushing is now.
05-21-2008, 03:41 PM
| | Re: Spark knock Can needle bearings be used where bushings were, and will the bushings and bearings be the same on all of the 2 stroke engines? 50cc 70cc, and 80cc. If so is this the size? KT101412 Needle Bearing Cage K 10x14x12:Ball Bearings:VXB
05-21-2008, 04:10 PM
| | Re: Spark knock Anyone try replacing roler bearing. I think mine is a 80 cc |
05-21-2008, 04:33 PM
| | Re: Spark knock I asked dax if the roller bearing would retro fit where the bushing is...he said no.
05-21-2008, 06:15 PM
| | Re: Spark knock Dax is out of the bushings, anyone know where I can get one. Seems like that is what is wrong with it. making that noise, kind of doing it as a maintenance thing. Make sure does not blow up. Heared it is the week link in the engine. Probably what is making that noise. |
05-21-2008, 06:16 PM
| | Re: Spark knock I am not even 100% that it is even a bushing just need to know where I can get the parts before I start taking it apart. |
05-21-2008, 06:58 PM
| | Re: Spark knock No idea....
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 06:33 AM. | | |
