| Sponsors
| | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Spark knock Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. You could probably press out the old one, get a slightly under sized replacement and then ream it out to ...  | |
05-21-2008, 06:59 PM
|  | Genius Visionary | | Join Date: Jan 2008 Location: Ashtabula county, Ohio
| | Re: Spark knock You could probably press out the old one, get a slightly under sized replacement and then ream it out to fit the wristpin.
05-21-2008, 07:10 PM
| | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Daytona Beach
| | Re: Spark knock Seems like if I got a slightly undersized one I should be able to get the right size one, Where would I get one? How do I press it out wonder if I could just use my C clamp. |
05-22-2008, 02:06 PM
| | Re: Spark knock You'd have to measure the wristpin and find one that was .003 over that measurement I think, or ???
05-22-2008, 02:34 PM
| | Re: Spark knock That might be an option, maybe I could start my search at a small engine repair place because Dax is out and it might be over a mounth untill he finds one. Maybe use a rat tail file then sand it smooth, what do you think? |
05-22-2008, 04:37 PM
| | Re: Spark knock Considering how loose they are from the start, many things will probably work.
05-22-2008, 05:40 PM
| | Re: Spark knock I didn't know they were loose when you get them. I wish some one had some dimensions for me just messure everything, so I could have the parts before I even get into it. |
05-22-2008, 06:05 PM
| | Re: Spark knock You do...you have a pattern for everything it's your bicycle engine.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 02:49 PM. | | |
