Spark knock
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. You say anti rotation pin I say ..... never mind...
  #11 (permalink)
Old 05-17-2008, 08:49 PM
deacon's Avatar
Default Re: Spark knock
visit my blog if you dare http://chinesekitmotorbike.blogspot.com/
Full novel on the blog in serial form.
  #12 (permalink)
Old 05-20-2008, 09:41 PM
Norman's Avatar
LORD VADER Moderator
I like tits too
norms-iron-works.tripod.com
  #13 (permalink)
Old 05-21-2008, 10:59 AM
Where can I get one of these bushings, so I can have it ready before I even put the engine back together. I guess needle bearings are going to be out of the question since they are probably not going to fit.
  #14 (permalink)
Old 05-21-2008, 03:16 PM
Bikeguy Joe's Avatar
Contact the original seller of your engine kit and ask if they can get the parts you are looking for.
No, a bearing will not retrofit where the bushing is now.
  #15 (permalink)
Old 05-21-2008, 03:41 PM
Can needle bearings be used where bushings were, and will the bushings and bearings be the same on all of the 2 stroke engines? 50cc 70cc, and 80cc. If so is this the size?
KT101412 Needle Bearing Cage K 10x14x12:Ball Bearings:VXB
  #16 (permalink)
Old 05-21-2008, 04:10 PM
Anyone try replacing roler bearing. I think mine is a 80 cc
  #17 (permalink)
Old 05-21-2008, 04:33 PM
I asked dax if the roller bearing would retro fit where the bushing is...he said no.
  #18 (permalink)
Old 05-21-2008, 06:15 PM
Dax is out of the bushings, anyone know where I can get one. Seems like that is what is wrong with it. making that noise, kind of doing it as a maintenance thing. Make sure does not blow up. Heared it is the week link in the engine. Probably what is making that noise.
  #19 (permalink)
Old 05-21-2008, 06:16 PM
I am not even 100% that it is even a bushing just need to know where I can get the parts before I start taking it apart.
  #20 (permalink)
Old 05-21-2008, 06:58 PM
No idea....
Similar Threads
Won't start - no spark (possibly) swodell Bicycle Engine Kits 17 06-06-2008 02:37 PM
Spark plug replacement sisdavid Bicycle Engine Kits 18 05-27-2008 02:42 PM
spark problem dazdog Bicycle Engine Kits 10 05-05-2008 09:27 PM
Spark plug wire and boot. ran49 Motorized Bicycle General Discussion 12 04-01-2008 02:39 PM
Loss of high RPM spark? Pablo Bicycle Engine Kits 93 03-28-2008 11:14 AM
