Single speed or multi-speed bike
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. I'm getting ready to make the "plunge". Going to go out tomorrow and look for a used ...
Old 07-10-2009, 06:50 PM
Default Single speed or multi-speed bike
I'm getting ready to make the "plunge". Going to go out tomorrow and look for a used bike. I live in hilly country. Do you recommend a single speed bike or multi-speed if used with a 66 cc engine? You can't "pull" these hills with a single speed bike and it is a real effort to do so with my 7 speed.
Old 07-10-2009, 06:58 PM
floridaboy's Avatar
Default Re: Single speed or multi-speed bike
Alot depends on your weight. If you are light you can use a smaller back sprocket. If you are a heaver person you will need a larger sprocket. Asfar as the type of bike you can use a coaster bike and have a single speed. If you want to be able to change speeds you will want a bike with gears. Then you can use what is called a jack shaft and be able to use the gears. I hope this helps you decide.
Old 07-10-2009, 07:35 PM
I weigh 180 lbs. I have a Currie 24 volt electric mountain bike with a 7 speed and have to assist the electric motor on steep hills. Does the gas engine have more or less torque than the electric motor? I don't have a problem with "assisting" the motor but I don't want to buy a gas kit and a single speed bike and have to "walk" it up the hills when if I had had a 7 speed or greater I could ride.
Old 07-10-2009, 08:24 PM
floridaboy's Avatar
I do not know anything about electric bike engines. I would think that a gas engine would have more torque. I have read on some of the post of people useing up to a 52T sprocket in some places that have steep slopes. When i said you could use a bike with gears and a jack shaft the jack shaft lets you use the gears the bike has. You can read about that set up at the Sick Bike Parts site.
Old 07-10-2009, 08:30 PM
I suppose I will find a multi-speed bike then I can go either way. Looking for a "Cruiser" but all I have seen so far is Mountain Bikes. I would like to sit more "upright". Thanks for the replies!!
Old 07-10-2009, 08:45 PM
2door's Avatar
ut1205,
Welcome to the forum. You've come to the right place for answers and suggestions. If you don't mind a cheaper department store, Chinese made cruiser may I suggest you look at the Schwinn Jaguar or it's clone the South Port (same bike, different color scheme) They are a cruiser style frames and both feature a 7 speed cluster with a twist grip shifter. As was suggested by Floridaboy, and you have the $, there is an optional shift kit available which will allow you to use the bike's gears to enhance the pulling power of the engine. Let us know what you decide and good luck. We're here when the time comes for further help.
Over Youth and Skill
Old 07-10-2009, 09:39 PM
Cabinfever1977's Avatar
the gas engines have a lot more torque than most electric bikes,thats why we build them. if you use a large enough rear sprocket,you wont have to peddal at all up hills.
Old 07-11-2009, 06:37 PM
Guess I will have to buy a bicycle. I've been to all the thrift shops and a couple of yard sales and didn't find anything worth having. In fact only found one bike and it was a mountain bike that appeared to have been left outside with no cover for about 10 years and they wanted $40.00 for it. Only thing that kept it standing was termites holding hands. Got another suggestion to check Pawn shops. May do that next week. Thanks for all the replies. All of you have been a big help.
  #9 (permalink)
Old 07-11-2009, 07:32 PM
old motorbike's Avatar
Try Craigs List or a police auction. I just sold my first build with a shift kit, and I loved it even here on flat ground. I think if you have hills steep enough that can't be pedaled up, you could use a shift kit (unless it's illegal) in your state.
  #10 (permalink)
Old 07-13-2009, 12:21 AM
Nashville Kat's Avatar
The one thing that's never mentioned- the derailleur on a multispeed bike acts like the chain tensioner otherwise- it adjusts the pedal chain and if there are no allignment probles otherwise- the motor chain tensioner can then be eliminated-
I recommend the Micargi mult-speed Pantera cruiser- the rear motor sprocket holes fit right on them with no altering, and a ridge stops the sprocket an eight of an inch from the spokes- there's no need even for the rubber then on that side. It's like they're made for the motor and sprocket otherwise- a trackkie flip/flop "fixie" hub is the same way, but may need to be spaced for a multi-speed freewheel, if a single freewheel isn't used. The track cog lockring is reversed threaded I believe and should hold the sprocket firm laterally at least- forward drive is then still needed- i'm hoping to drill a sprocket to fit directkly on a flip/flop rear hub.
A dual brake lever then is desirable on any bike with handbrakes, and works very well, and I personally like handbrakes, and don't want to alter sprockets for coaster hubs
Peadal assist may help on big hills, I like to pedal a bigger gear down from a faster motor driven speed, or shut the motor off to cool and save gas on long descents- not pressing fast all the time. I'm pushing close to 200 pounds, and my 36 is bogging down a little bit on the really steep hills here in Brown County IN, Hilly Hundred country- but still getting up them, and I expect to riding mostly on the flat soon,
and the 36 gives a good cruise speed-
a 40 tooth may be a compromise down from 44, and I've seen them at "Livefast motors" on ebay, in their upgrade kit-
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f3/single-speed-multi-speed-bike-9506.html
Posted By For Type Date
Single Speed - Blogs, Pictures, and more on Blogged This thread Refback 08-02-2009 04:28 AM
