Single speed bicycle or one with gears?
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Hello everyone, I am planning on getting the Titan motor kit after the first of the year and have a ...
Old 12-07-2008, 07:12 AM
Default Single speed bicycle or one with gears?
Hello everyone,
I am planning on getting the Titan motor kit after the first of the year and have a few questions.
1. Is there a difference in using a Single speed bike or multi speed bike with an engine, if so which would be better?
2. I have read about needing to change the rear wheel to something heavier duty, what spoke size or other recommendations?
3. What horse power is the Titan? I live in Illinois, and to be legal I can have no more than 2 brake horsepower.
Thanks...
Old 12-07-2008, 11:15 AM
fairracing31's Avatar
Default Re: Single speed bicycle or one with gears?
Hello ilkeeper, Welcome to the forum
I use a single speed bike and I like it very much. But, I do have to admit the bikes I have built for others were multi-speed and I found it much easier to pedal with them then my single speed.
As far as changing the wheel and the horsepower of the titan....I am not sure. Hopefully someone else can jump in here and give info on that. And I will keep a close watch so that I will know for the future.
Interested in Alternative Energy? http://nature2energy.com/
Old 12-07-2008, 11:30 AM
I have a girlie single-speed cruiser with front brake, and a Raleigh 7-speed cruiser bike. I like the 7-speed because:
MUCH better braking
ability to pedal-assist at high speed
easier pedalling at any mph
I recommend HD rim, 12-gauge spokes and high-speed grease. Also, secure the spokes where they crisscross with tiewraps.
I have 12-gauge spokes and HD rims front and rear. I have NEVER broken or even loosened a spoke with my 2.2 hp Staton friction or chain drive assemblies.
Old 12-07-2008, 05:25 PM
When you say HD, you mean....
Old 12-07-2008, 05:27 PM
jasonh's Avatar
heavy duty
Old 12-07-2008, 06:00 PM
TexasDav's Avatar
The cheap rims and spokes and bearings on the wally world bikes give out quickly when using a motor. I can tell you from experance. I am ordering myself a heavy duty rim from Husky today.
WHEEL 26x2.125 rear coaster brake, 120g, steel (HD-120): Husky Bicycles
Old 12-07-2008, 09:39 PM
Technocyclist's Avatar
before anything else, check the OLD (Overall length Diameter) of your dropouts. Having more gears would require you to have a wider OLD. Or you can use a frame expander tool to fit a wider hub with more gears.
Having more gears is definitely better than single speed. It gives you more flexibility on the type of terrain you can go through. However, multi-speed uses a thinner chain, and single speed uses a thicker chain. I'm using an 8 speed internal gear hub, allowing me to use thicker, more durable, BMX chains. I have experienced snapping multi speed chains, so choose a very good quality chain also.
Heavy duty hub, spokes, and rim is a must for a motorized bicycle.
Most engines for bicycles are limited between 1 to 2 HP that is below 50cc. I'm not sure about the Titan.
It's more than a hobby, it's my transport.
Caution: This hobby is habit forming.
Old 12-08-2008, 01:00 AM
xPosTech's Avatar
The Old Master Motorized Bicycle Builder
Thought that was Over Locknut Dimension?
Techno is right about the respacing of the OLD of your bike but be aware you can't expand an aluminum framed bike.
There are shifter kits available from SBP that allow you to use the engine via the gears. See the links at the left.
When you get down to it the in hub gearing has derailleurs beat all to heck. Everything is enclosed keeping out dirt, rain, snow and salt, etc. OLD from 110mm to 150mm.
Ted
I wasn't born in Texas but I got
back here as soon as I could.
Help support the forum.
Donate today.
  #9 (permalink)
Old 12-08-2008, 01:22 AM
You're right Ted, but actually, OLD is 'Over-Locknut-Dimension'... So sorry for the confusion... getting too old for this abbreviations and stuff...
Sheldon Brown's Bicycle Glossary N-O
  #10 (permalink)
Old 12-08-2008, 12:51 PM
Ted
Thanks for everyone helping me out, I'm learning a lot here.
On the shifter kits, does anyone know if they are legal in Illinois?
Our rule of the road says (Power drive system shall not require the operator to shift gears.)
Thanks...
« LOL China | Hello »
