Shimano Wheel
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. I decided to start a new post from Ripped Spoke, since I now am trying to change over to a ...
Old 07-15-2008, 11:18 PM
Default Shimano Wheel
I decided to start a new post from Ripped Spoke, since I now am trying to change over to a Shimano 26 X 2.125, Hub-Shim CB 12G 34H.
I did not expect the brake arrangement and am hoping someone here is familiar with it.
The brake arm is different than conventional in shape and holds its place by a start type attachment that looks alot like the adjustment nut in the clutch housing.
Anyway, when tightening the engine rear wheel chain sprocket to the wheel, when it gets tight the wheel will not
spin, some how pressure on the brake nut cap stops the wheel spin action, . . has anyone dealt with this ?
If this can't be fixed, . . I guess, I will have to inter-change
the hub parts, from the old wheel, if they fit ?
Old 07-15-2008, 11:21 PM
Default Re: Shimano Wheel
I did replace the pedal chain sprocket, took out the Shimano assembly, since it did not have a chain sprocket mounted. It fit well and the wheel spun free until I tightened down the engine sprocket.
Last edited by Wheel Rush : 07-16-2008 at 12:32 AM. Reason: additional explanation
Old 07-16-2008, 09:40 AM
All that I can tell you at this time is that D--mn Hub must be super sensitive ! I loosened all the bolts on the sprocket and tightened them
slightly until the, (altered by adjustment), brake arm, cleared, . .
this left the bolts not very tight, but close to snug, and it the wheel spins OK.
I'll true it out a little and tire it up for a try, . . don't know what else can go wrong, . . but that was a little frustrating, .
Old 07-16-2008, 10:51 AM
Runs, we'll find out how well ?!
Similar Threads
Removing crank pin from fly wheel? ran49 Motorized Bicycle Trouble Shooting 2 07-08-2008 09:51 PM
Searchin' fo a wheel. deacon Motorized Bicycle General Discussion 0 06-11-2008 05:29 PM
Bearing in rear wheel sisdavid Swap And Shop 12 06-09-2008 05:47 PM
I want my wheel back deacon The Tavern 0 05-20-2008 03:32 PM
Wheel observations.. deacon Motorized Bicycle General Discussion 1 05-13-2008 09:32 PM
