| | Shaker style choke pull Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Well Ok, I didn't go to industrial design school.LOL,I figured this will work until I or someone ...  | |
03-27-2008, 10:24 PM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: So.In.
| | Shaker style choke pull Well Ok, I didn't go to industrial design school.LOL,I figured this will work until I or someone else can come up with something better.Cable to the grip would be nice.I gotta say though,this works pretty darn good.Easy to fetch with your left hand without running into a ditch.Ron
[IMG]  [/IMG] |
03-27-2008, 10:55 PM
| | Re: Shaker style choke pull Mr. Gasket 2078 choke cable $10.00. Check out JC Whitney, I beleive they have alot of choke cables to offer you. Your local auto parts store should have choke cables. |
03-27-2008, 11:08 PM
| | Re: Shaker style choke pull Thanks Fair
I'll look into it.Ron |
03-28-2008, 05:01 AM
| | Re: Shaker style choke pull Can't see what it's made from, Ron.
If it works then great....the choking/pedalling/not watching where you are going thing can get interesting.
03-28-2008, 08:25 AM
| | Re: Shaker style choke pull Here's a larger pic.
I used a 1/8" copper rod I had laying around , beat a flat on one end and drilled a 1/16" hole through it.Used a dremmel to cut a slot in the top tab of the choke lever(long enough to allow full travel). Pinned end of rod between the two choke lever tabs with a piece of wire.Took a thin strip of metal bent in half to form a sleeve and taped to seat tube.Sawed off Shaker peg for handle.
Not the most eloquent solution but sufficiently goofy enough to have a certain appeal.Ron
[IMG]  [/IMG]
03-28-2008, 10:40 AM
| | Re: Shaker style choke pull I like your design it works and is simple,easy to do, anyone should be able to do the same. good job!
Norman
03-28-2008, 10:46 AM
| | Re: Shaker style choke pull What I don't understand is why you need a choke lever. My engine warms up in seconds. I just start the bike in my drive, let it warm up, turn off the choke and go. takes about three minutes from first pedal to hitting the streets.
Are there motors that take longer to warm up. If so I might need to do something different for my next build. |
03-28-2008, 02:00 PM
| | Re: Shaker style choke pull Now there's a thought Deacon.Although I have a pretty good hill at the end of my driveway and have grown accustom to a gravity assisted start.Ron |
03-28-2008, 02:57 PM
| | Re: Shaker style choke pull My engine on my motorized bicycle wont start without a choke when it's cool outside. In warm weather it will start fine with no choke. But if it's below 50 degrees it's got to be choked. I've been talking about fixing a choke like that. I've come close to wrecking a time or two because I was looking for the choke...............
__________________ There are only 10 kinds of people in this world. Those that understand binary and those that don't............ http://bdconner.com
Reason: because I can......
03-28-2008, 03:28 PM
|  | Master Motorized Bicycle Builder | | Join Date: Feb 2008 Location: Metro Washington, DC
| | Re: Shaker style choke pull Quote:
[IMG]  [/IMG] | I love your engineering style Ron. This is by far the simplest choke lever I've seen. The Shaker knob is genius  Thanks!
__________________ Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 05:53 PM. |
