| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | serious loss of power Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. my second build has been running beautifuly for 5 months. it now has no power at all, it lost all ...  | |
02-15-2009, 12:17 PM
| | Motorized Bicycle Member | | Join Date: Jul 2008
| | serious loss of power my second build has been running beautifuly for 5 months. it now has no power at all, it lost all power in a small 15 minute trip into town. it will get up to speed on a flat road but as soon as the slightest hill comes along i slow down so much that if i dont pedal it will stall. havent changed anything on it exept the stock plug and lead when i 1st built it.... i am so confused as to what is going on with it. i tried running a little leaner. all that did was heat the engine up faster, so i tried running richer and it still has no power.
time for a new build or can u guys fix it?
ps its not compression .. she has plenty of that.  |
02-15-2009, 12:28 PM
|  | MANIC Mechanic | | Join Date: Sep 2008 Location: Clearwater, FL
| | Re: serious loss of power Quote:
Originally Posted by smithmule my second build has been running beautifuly for 5 months. it now has no power at all, it lost all power in a small 15 minute trip into town. it will get up to speed on a flat road but as soon as the slightest hill comes along i slow down so much that if i dont pedal it will stall. havent changed anything on it exept the stock plug and lead when i 1st built it.... i am so confused as to what is going on with it. i tried running a little leaner. all that did was heat the engine up faster, so i tried running richer and it still has no power.
ps its not compression .. she has plenty of that.  | Check the exhaust pipe...It may be clogged.
Jim |
02-15-2009, 12:31 PM
| | Re: serious loss of power checking that right now .. typing with greasy hands
Edit: clean and clear of clogs. i dont think i will buy gruubee again, my zbox engine is built so much better.
Reason: update
02-15-2009, 12:50 PM
| | Re: serious loss of power If it has compression, and is not running lean due to an air leak, (light or white plug) then check for binding rear wheel bearings, or other drive train issues.
02-15-2009, 01:05 PM
| | Re: serious loss of power wheel and chains move freely (with clutch pulled in of course)tomorrow i will try swapping parts from the good bike 1 by 1 |
02-15-2009, 02:34 PM
| | Re: serious loss of power What does the plug look like? |
02-15-2009, 02:37 PM
| | Re: serious loss of power has a little blacky brown residue .. not really much |
02-15-2009, 03:12 PM
| | Re: serious loss of power do you have any oily residue under the mag cover or under the clutch cover all of it will be where the crankshaft comes through the crankcase on either side? you might have a main crank seal leaking/going bad and oily poo with some black dust is a dead giveaway of a seal leaking. some engines are assembled with seals that are damaged when they are assembled they will run fine for awhile then get to running sorry and keep getting worse until you either trash out the engine from it running lean for hopefully find the problem before it gets that bad.
Norman
02-21-2009, 11:34 PM
|  | Motorized Bicycle Elite Member | | Join Date: Oct 2008 Location: Tampa Bay, FL
| | Re: serious loss of power You might have what Jim just discovered in my first motor over the weekend.
One of my crank bearing seals was placed on the inside of the motor; thus shielding it from any lubrication whatsoever. The crank barely moved and was heading for a seize up. Jim found melted rubber in my case around one crank bearing. The motor had very little miles on it, but it was too late by the time the seal melted away. The motor was losing power daily.
Where did you get your motor?
'BrettMavriK |
02-24-2009, 01:36 AM
| | Re: serious loss of power got it from a gasman resaler near fairy meadow (south of sydney) i stripped it bare just yesterday and cannot see a single thing wrong with it. put it back together and it still has no power. it will get up to speed on a flat but the 1st sign of a hill and it slows right down to a crawl. i have given up on it and am buying a new zbox engine. i dont think i will ever buy grubee again. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 08:13 AM. | | | Sponsors
