Running full blast
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Actually, I run my Homelite weedwacker at a speed just off-idle. I've run it this way for the ...
  #11 (permalink)
Old 05-04-2008, 02:14 PM
Bikeguy Joe's Avatar
Default Re: Running full blast
Actually, I run my Homelite weedwacker at a speed just off-idle. I've run it this way for the last 8 years without so much as a plug change or de-carbonizing.
I run Sea Foam through it once or twice a year.
I run my chainsaw(s) about half to three quarters throttle 90% of the time and one is over 10 years old.
Run your bicycle motor the way you feel comfortable. They will either blow or run forever.
  #12 (permalink)
Old 05-04-2008, 05:04 PM
Banned
Bikejoe,
I disagree with your logic mainly because every doubling of engine speed causes increased frictional forces by 4 (friction is exponential). If friction is main cause of engine longevity than decreasing engine speed by 25% would mean a greater than 25% increase in longevity.
  #13 (permalink)
Old 05-04-2008, 05:55 PM
I think you are correct sir!
If I am correct, then it would be a good thing, if you are correct, then it would be a GREAT thing.
Like my weedwacker and chainsaw, by your reasoning, an engine run at lower speeds should last nearly forever.
  #14 (permalink)
Old 05-04-2008, 05:57 PM
What say you to that?
  #15 (permalink)
Old 05-04-2008, 06:07 PM
Banned
Yes, that's pretty much true. In many 3rd world countries in remote villages, the villages use Lister diesel generators. The generator runs at a constant 600 rpm and these generators have been known to last 40+ years without overhaul and shutdown only for oil changes and other maintenance.
  #16 (permalink)
Old 05-05-2008, 07:14 PM
deacon's Avatar
I don't know if this has been answered before or not but does anyone know the rpm output of these engines at full throttle.
  #17 (permalink)
Old 05-05-2008, 08:57 PM
Info could be as accurate as the term 80cc but 2.4 horse at 4000rpm and they rev out at 6000 to 7000. If you were at 4000 rpm you would be getting the full power band as it would tend to mellow out after that. (At least on a Dyno, on paper )
  #18 (permalink)
Old 05-05-2008, 09:03 PM
deacon's Avatar
thanks that helps me a lot. I had a little bit of fear about trying to put a friction drive on one but that is pretty close to an electric motor I have used a friction drive on so it should be okay.
  #19 (permalink)
Old 05-06-2008, 05:48 AM
I think the manufacture states 6300 as "redline"- to be taken with a grain of salt.
I know a lot of folks say that 35mph is about tops with a 44T, I have run one of my bikes up to 43-5 with a 44T with two different cars used as "pace cars". The engine is still running.
  #20 (permalink)
Old 05-12-2008, 12:28 AM
Maybe I will slow it down a bit.
Similar Threads
Running REALLY rich.....which way... Pablo Bicycle Engine Kits 28 06-19-2008 11:32 PM
Running on half choke frenchman159 Motorized Bicycle General Discussion 31 05-11-2008 03:50 PM
Full suspension Bike, Anyone? TINKERER Pre-Motorized Bicycle Information. 4 03-23-2008 11:31 AM
bicycle motor running fine! CRUISER Travels and Adventures 11 03-17-2008 11:01 PM
I got it running spad4me Bicycle Engine Kits 3 01-21-2008 04:55 PM
