Rpm
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Hey guys About what RPM are these happytime 70cc engines hitting at the top end? Thanks Ron...
Old 04-12-2008, 03:24 PM
ran49's Avatar
Default Rpm
Hey guys
Thanks Ron
Old 04-12-2008, 05:49 PM
Norman's Avatar
LORD VADER Moderator
Default Re: Rpm
I don't know I've never put a tach on one to find out I just rev it until it won't go no faster, but only under a load don't wind it out with out a load or the insides will very quickly be on the out side.
norms-iron-works.tripod.com
Old 04-12-2008, 06:06 PM
ran49's Avatar
Default Re: Rpm
"I just rev it until it won't go no faster" Thats what I'm talking about.Average bike,44tooth sprocket,level ground.Any guesses?
Old 04-12-2008, 06:23 PM
Bikeguy Joe's Avatar
Default Re: Rpm
6000-6300 is what I've read somewhere.
Old 04-13-2008, 12:03 PM
Andyinchville1's Avatar
Manufacturer/Dealer
Default Re: Rpm
I Use a Sen Dec Tach and have had my motor up to 6300 RPM.....Didn't want to go further for fear of blowing the engine...(I have a Dax 70).
Andrew
Sprockets now available in 9 anodized colors!
http://www.myspace.com/kingssalesandservice
http://www.youtube.com/watch?v=-zyU8n41f2c
Old 04-13-2008, 01:25 PM
fairracing31's Avatar
Default Re: Rpm
I will be using a digital hour meter/ tachometer on my next build.
Works on all 2 & 4 strokes
Internal battey
Displays RPM when engine is running automatically displays run time in hours when motor is off
Programmable service check function helps precisely schedule needed maintenance
My local Go-Kart shop has one, here is the same one for a few $$$ more from Northertool.com part # 160590
Old 04-14-2008, 03:27 AM
Motorized Bicycle Apprentice
Default Re: Rpm
I made a chart with a gearing calculator and taped it to the bars.
6000 = 48kmh which sounds a little strained.
It will easily run up over 50 on flat ground...
Half throttle is 44kmh on the flat which is my normal cruising speed.
That is 5500rpm and it sounds happy there.
Old 04-14-2008, 09:21 AM
ran49's Avatar
Default Re: Rpm
Wild,Are you saying 50MPH! What sort of setup you running.With my 44 tooth 70cc anything over 27MPH is like those old test pilots trying to break thru the sound barrier.Handlebar vibrates to the point where it's almost painful to keep your grip.Ron
  #9 (permalink)
Old 04-14-2008, 09:27 AM
CRUISER's Avatar
ADMINISTRATOR
Default Re: Rpm
i think he is saying kilometers per hour
  #10 (permalink)
Old 04-14-2008, 09:48 AM
ran49's Avatar
Default Re: Rpm
lol,I see that now.Probably ought to have my eyes examined before I get back in the saddle!Thanks,Ron
