Ripped Out a Spoke ?
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. I now am pretty sure that tightening down the sprocket to the rag is causing the wheel to not spin , . . ...
  #31 (permalink)
Old 07-15-2008, 08:10 PM
Default Re: Ripped Out a Spoke ?
I now am pretty sure that tightening down the sprocket to the rag is causing the wheel to not spin , . . as if the brake is on.
In post 23, I asked if anyone had experience with the Shimano,
Is anyone familiar with a Shimano 26 x 2.125
Hub Shim CB 12G 36H ?, It is essentially a nice looking wheel, but I have never seen a coaster brake assembly like this the brake arm rest on a, "segmented star arrangement", of sort, has anyone dealt with this, before I have to go take a picture ?
Anyway the wheel will not spin now that I have tighten down the engine wheel sprocket, what changed ?
  #32 (permalink)
Old 07-15-2008, 08:31 PM
Bikeguy Joe's Avatar
Genius Visionary
Picture?
Are the bolt heads interfering with the brake arm?
  #33 (permalink)
Old 07-15-2008, 09:21 PM
No, It has gone from moving the brake arm freely to very hard moving it, This I believe is being caused by the tightening of the engine rear wheel sprocket ? I can't find anything on this, (Shimano 26 x 2.125
Hub Shim CB 12G 36H), the part the brake arm holds onto looks like the clutch center adjustment nut, (star shaped) Have you seen this before ?
  #34 (permalink)
Old 07-16-2008, 10:55 AM
All that I can tell you at this time is that D--mn Hub must be super sensitive ! I loosened all the bolts on the sprocket and tightened them
slightly until the, (altered by adjustment), brake arm, cleared, . .
this left the bolts not very tight, but close to snug, and it the wheel spins OK.
I'll true it out a little and tire it up for a try, . . don't know what else can go wrong, . . but that was a little frustrating, .
Ok, to close out this thread;
Runs, we'll find out how well ?!
Advertisers
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
