| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Replace/Repair/Adjust Chain Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. What kind of bicycle motor kit do you have?...  | |
07-10-2008, 07:38 AM
| | Re: Replace or Repair Chain? What kind of bicycle motor kit do you have?
07-10-2008, 11:01 AM
| | Re: Replace or Repair Chain? Yes, I too would like to know  |
07-10-2008, 01:32 PM
|  | Moderator | | Join Date: Jan 2008 Location: Shelby MI
| | Re: Replace or Repair Chain? I would guess that you have alighment issues. the width of the chain shouldn't matter if your sproocket and motor sprocket are alighned. Some of the kits come stock with a 415 which is even wider, this is what I use. I think I have one more 415 left then I will switch to the 41...Kelly
I'm racin' Spitfire, turnin', poppin' wheelies, burnin' evil chasin' pop,pop, pop,pop,pop.... (The Pixies-Tony's theme)
07-10-2008, 04:20 PM
| | Re: Replace or Repair Chain? I think you have alignment issues too.
07-11-2008, 03:48 PM
| | Re: Replace or Repair Chain? Adjusting the chain
You want to have at least 1/2-3/4 inch of slack in your chain. To tight is just as bad as too loose.
With a tape measure...measure from the bottom chain stays to the top of the chain (the drive part). Alway's measure from the same place...I use my chain tensioner as a guide (about a inch and half away from it) Measure in the middle between the sprocket's.
Measure the chain first
Now with your finger pull up on the top chain (drive part) until all slack is gone...As you can see I have about a inch of slack...too much
Use your tensioner to adjust..If you do not have enough adjustment on your tensioner...moving it back (towards rear sprocket) should give you a little more adjustment. If you can't do that...you may have to remove a link. If you remove a link, you may also need to move the tensioner back towards the engine. BE SURE!! removing a link will not make your chain too short!!  |
07-11-2008, 03:55 PM
| | Re: Replace or Repair Chain? Here it is adjusted to 3/4 inch... The measurements are not exact in the pic's...it was too dificult to hold camera tape measure and chain all at the same time. But it should give you a good ideal how to go about it.
How to remove link with bench grinder coming soon |
07-11-2008, 05:38 PM
| | Re: Replace or Repair Chain? I want to chime in and say rotate your rear wheel and find where the chain its at its tightest and use that point to set the slack in your chain. I run mine more on the loose side than tight.
Norman
07-18-2008, 07:58 PM
| | Re: Replace/Repair/Adjust Chain #415 Chain.....
Pitch: 1/2
Roller Diameter: .306
Between Inner Plates: 3/16
Pin Diameter: .141 #41 Chain....
Pitch: 1/2
Between Inner Plates: 1/4
Pin Diameter: .141 Azusa Engineering, Inc. Online Catalog - Roller Chain, Motorcycles, etc.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 02:12 PM. | | | Sponsors
