removing handle bar grips
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. this used to be a bear of a task for me. you either had to cut them or rip them ...
Old 12-24-2007, 05:30 AM
CRUISER's Avatar
ADMINISTRATOR
Default removing handle bar grips
this used to be a bear of a task for me. you either had to cut them or rip them off. their is a quick and easy way to replace them. take your air compresor with a blowing tool and just lift a part of the end of the grip and give it a blast of air and they slide or pop right off. same as putting new ones on. give it some air and they slip right on. a small tip but a great one
Old 12-28-2007, 09:20 PM
ChrisHill's Avatar
Manufacturer/Dealer
Default
Not all of us have air compressors, but those that do will enjoy Cruiser's tip.
Here's a good one for those that don't...
To slide new grips on your bars...take a drop of dishsoap on your finger and smear it around the inside of the grip. The grip will slide up on the bar without a hassle, and the soap will dry up and help to stick it there.
Just so everyone knows...the stock grips from your bike, or a fancy pair of store bought grips can be used to replace the stock grips that come with the majority of bicycle engine kits (mine included). Just work the original off and use my above tip to slide the new grip on...it may be tight, but that is a good thing.
Yes, I really do ride what I sell...everyday.
www.chrishill.myknet.org
Home of the CH80 Bicycle Engine Kit...for those that want quality.
Old 12-28-2007, 09:27 PM
CRUISER's Avatar
ADMINISTRATOR
Default
wow1 you mean you can slip them over the throttle grip. i have some really nice grips in my drawer of goodies and never tried but i sure am in the morning. thanks for the great tip chris
http://stockmarketcats.com/
Old 12-29-2007, 07:20 AM
ChrisHill's Avatar
Manufacturer/Dealer
Default
They'll fit but they are tight. A drop of dishsoap smeared inside of the grip will help more than you can imagine.
I had to mention swapping the grips, because I know for a fact that a lot of bicycle engine kits come with very lame grips, lol...except for my engine kits
Old 01-01-2008, 01:15 PM
MotorbikeMike's Avatar
Dealer
Default "Airless" removal
Hi if you don't have air, slide a dull butter knife, spoke or whatever under the grip, spray in windex, repeat till you can slide off that grip. I have done this many times. Old crappy grips I don't care about are slit with razor-knife.
Mike
www.simpsonmotorbikes.com
Home of the 08 Racer and
NEW Model 10 production bikes
Old 01-10-2008, 07:14 AM
Bikeguy Joe's Avatar
Default Re: removing handle bar grips
One more tip-
To remove the old ones, heat is our friend....boiling water poured (carefully) on them, or better yet, use a heat gun or hairdryer.
Old 01-10-2008, 09:19 AM
iRide Customs's Avatar
Paul,
If you want to install new grips on your thottle, try motorcycle grips. One is bigger on the inside to fit the throttle.
Dan
Old 01-10-2008, 09:35 AM
CRUISER's Avatar
ADMINISTRATOR
cool thanks dan. i am going to head to the motorcycle shop and look at grips and some mirrors. planing on replacing my throttle i have a cheap plastic on and the better ones you can put your own grips on. will let you all know what i come up with
  #9 (permalink)
Old 01-17-2008, 01:10 PM
Norman's Avatar
LORD VADER Moderator
I use plain water sprayed in between the grip and bars while pryed open with a small flat bladed screw driver to remove the grips and like one of the guys said if your not going to reuse cut them off. Once I've sprayed in the water I twist the blade around the grip to let the water get all the way around and it will come right off.
I like the foam grips soft and they absorb the vibes cheap to get a couple sets for about $5.00 includes shipping on flea bay. to install spray a little water inside the grip and push it on They come with end plugs and I use a bar end mounted mirror on the left side that's really for the right side its on upside down but out of my way and easy to see behind me its also convex anyway it works for me. If you run into trouble with the grip on the throttle side I've used weatherstrip glue or quick set JB-weld to hold the grip in place being careful not to glue the grip to where it fowls up the throttle. There's some of my ideas and I'm sure there's plenty more so chime in and lets share the knowledge.
Norman
