| Sponsors
| Our Forums | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | removing and adding chain links on motorized bicycle chain Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Originally Posted by astronut
why dont you guys just use the real chain breakers?
I mean they are dirt cheap ...  | |
05-02-2008, 06:02 AM
| | Re: removing and adding chain links on motorized bicycle chain Quote:
Originally Posted by astronut why dont you guys just use the real chain breakers?
I mean they are dirt cheap and work better than the bicycle ones.
a good one is like $10. a cheap one is like $5.  | Frankly because those big ones are a pain in the ass on smaller bike chains! In reality it's good to have both. |
05-02-2008, 07:58 AM
| | Motorized Bicycle Senior Member | | Join Date: Mar 2008
| | Re: removing and adding chain links on motorized bicycle chain PABLO: yes youre right they are not as good for the regular or "ultra" slim bicycle chains, because they are considered WAY too heavy to carry around with you on rides and tours. the little bicycle ones wich are similar to the ones on the previous page, are lighter and do the job just fine (for bicycles), and are manufactured from things like aluminium too. these however work fine for the shop, and since we arent pedaling carrying one is not a problem.
These are actually much, much easier to use than the standard bicycle chain breaker. when you say they are too big, you might have come across the larger ones that open chains in some automotive applications for example. that would be too big and more like $25.99. there are different sizes of chain breaker. there are some so small you CAN'T use them on a bicycle chain.
BIKEGUY JOE: its best to look in person to see the right size and to save some money on shipping. it makes no sense to pay $7 shipping for an item that costs between $5 and $15 that you can get at any automotive shop, or even sears for that matter. just pull over on your way from work or a shopping trip.
I would advise to get something decent, instead of going too cheap because a good one these things will last decades (mines used to be my grandfather's). it's a one time purchase. the ones in the 98cent store near my home sells for $4.99 and it looks like its ready to come appart. while for $10 you can get a good one that will last longer. Alternatively you can just get AMERICAN MADE and it will last as long as you. for more money you can get nice rubber on the handles if you have sensitive hands, although its so easy to turn I dont see why. Or you can spend $30+ at motorcycle shops and get them with cool "radical" colors too.
this is the size we need for these applications, NOTE: size #41 chain. a very good US made chain breaker Roller Chain Breaker #25, 35, 41, 42, 50 & 60, USA Made - eBay (item 260234578188 end time May-03-08 21:35:51 PDT)
this is one thats too large cheap chinese breaker, I found the smaller version for$5 eBay Motors: Daido Chain Breaker #60 - #100 New in Package (item 120254296991 end time May-04-08 16:03:30 PDT) |
05-02-2008, 08:24 AM
| | Motorized Bicycle Elite Member | | Join Date: Mar 2008 Location: Ontario
| | Re: removing and adding chain links on motorized bicycle chain Until a couple of weeks ago, I was like you Pablo, thinking that the pin end was "rounded over" or mushroomed. From what I learned the pins are not like this at all and even grinding is not needed. That is why a punch and hammer works. It seems to be a friction fit. |
05-02-2008, 10:04 AM
|  | Motorized Bicycle Elite Member | | Join Date: Apr 2008 Location: Valparaiso, IN
Originally Posted by toytime Until a couple of weeks ago, I was like you Pablo, thinking that the pin end was "rounded over" or mushroomed. From what I learned the pins are not like this at all and even grinding is not needed. That is why a punch and hammer works. It seems to be a friction fit. | You are exactly right- a chain breaker is great, but a punch and hammer works fine. I never grind the end of a pin. If you do, it may not hold well if you try to reuse it....which often happens. To use a punch, just put the link up on an old small socket so the pins has somewhere to go, put the punch on the pin, and drive it out. |
05-02-2008, 11:01 AM
| | Re: removing and adding chain links on motorized bicycle chain thank you, I was bit hesitant to post that because if you look at the pin when it's in place you would swear that it is mushroomed. Common sense would also tell you that it should be mushroomed. Thing is that if you look at the pin when re-moved, it's just a smooth pin....very odd, yet that's how it is. |
05-02-2008, 11:21 AM
| | Re: removing and adding chain links on motorized bicycle chain Nice posts guys!
Yeah it's not mushroomed over. Agrree!
I may just buy the large Made USA one. I almost did awhile back.
I tried to punch out the pin on some new, nice #41 chain - the pin would NOT budge!!!  |
05-02-2008, 02:53 PM
| | Re: removing and adding chain links on motorized bicycle chain Thanks astronut....Sears it is!
05-07-2008, 10:13 PM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: Corpus Christi, Texas
| | Re: removing and adding chain links on motorized bicycle chain Here a thought, Bike factorys and parts supply folks  Belt drives work real well on Suzuki, & Harleys, so why not motorbikes |
05-08-2008, 06:36 AM
| | Re: removing and adding chain links on motorized bicycle chain If only somebody made one......
05-08-2008, 11:04 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2008 Location: Treasure Coast, Florida
| | Re: removing and adding chain links on motorized bicycle chain I punched my new #41 chain to fit. It was hard but you just need to hit it hard once. I did it with a socket and a punch. The old 415 chain was VERY easy to punch out. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 05:04 AM. | | |
