| | removing and adding chain links on motorized bicycle chain Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. the park chain breaker you were looking at is a good one and i believe park has a lifetime warranty ...  | |
03-01-2008, 10:09 AM
|  | ADMINISTRATOR | | Join Date: Dec 2007 Location: St. Croix, US Virgin Islands
| | Re: removing and adding chain links on motorized bicycle chain the park chain breaker you were looking at is a good one and i believe park has a lifetime warranty like craftsman. for the top use the one you took off use the 2 pieces. on the bottom of this picture and use your tool to press the pin. nothing needs to be rounded off. they fit tight. alot better then a master link and stronger. to me the master link is the weakest link so i do away with them. i can acutually do it this way faster then with a master link also. the cheap kmart schwinn breakers etc are the ones that bend and break.
03-01-2008, 10:23 AM
|  | Amsoil Dealer | | Join Date: Dec 2007 Location: Duvall, WA PNW
| | Re: removing and adding chain links on motorized bicycle chain Got it. Great pics of the tool. This picture says it all:
I did not realize there are more than one slot(s) in the tool. Makes total sense now. When I did mine rude and crude - ON THE BIKE - without a tool (it can be done, but it's difficult) I used a little anvil in back, and a flat punch to round the head over a bit.
Yep - I'm buying that Park tool. |
03-01-2008, 10:29 AM
| | Re: removing and adding chain links on motorized bicycle chain key to it is only press enough for pin to drop thru cap it will give and fell a click when you are free then do the other pin and remove the cap and slide out the other part. when you get the tool practice a few times with some of your extra links you have. once you get the hang of it you can replace or ad links in a second.
03-08-2008, 02:03 PM
| | Re: removing and adding chain links on motorized bicycle chain Yeah I got my Park tool. That sucker works REALLY nice. |
05-01-2008, 05:06 PM
| | Re: removing and adding chain links on motorized bicycle chain The ONLY problem with the Parker tool?
It will not work with #41 chain.....bummer....
I have an idea though. If I file/grind the pin head and then try the little tool it just might work. |
05-01-2008, 05:58 PM
| | Re: removing and adding chain links on motorized bicycle chain mine worked with the 411 no problem pablo.
05-01-2008, 06:03 PM
| | Re: removing and adding chain links on motorized bicycle chain #415 -si
#41 - no |
05-01-2008, 06:07 PM
| | Re: removing and adding chain links on motorized bicycle chain si for me pablo but come to think of it i used the park ct-3 and not the ct-5
05-02-2008, 04:18 AM
| | Senior Motorized Bicycle Builder | | Join Date: Mar 2008
| | Re: removing and adding chain links on motorized bicycle chain why dont you guys just use the real chain breakers?
I mean they are dirt cheap and work better than the bicycle ones.
a good one is like $10. a cheap one is like $5.  |
05-02-2008, 05:58 AM
| | Re: removing and adding chain links on motorized bicycle chain Where do I get one? I bought a Park ct-5 and I don't know if it's going to last any longer than my P.O.S. Bell breaker I got from W-Mart.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:39 PM. |
