OK, so.. I finally got my rear shock off...
It was nice to find the rear of the bike is only held on by a plastic cap with plastic threads in it. . .
Dual suspension while using the stock left gear drive = BADD just for the record.
I'm planning to just stick a steel tube in it with tire rubber on each end.. (if that works I *should* be able to use the screw adjusters as a chain tensioner.. and ditch the tensioner completely.)
So, now the only problem is, I can't get the spring off without damaging the aluminum threads...
I'm thinking dremel. yeah the disc will shatter and go flying when the springs pops.. but, hack-saw sound more dangerous.. and grinder would probably make alot of heat...
anyway, cutting = current plan.. planning to do it soonish.. try to stop me while you can...
(bike is ->
NEXT Avalon... Jet "80"cc stealth.... will it fit? over there btw..)
