| Sponsors
| | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | REAL 80+ CC Happy Times! Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. HI All,
I was just looking at an old partially disassembled engine today and was thinking of a low $$ way ...  |
07-12-2008, 09:42 PM
|  | Manufacturer/Dealer | | Join Date: Dec 2007 Location: Charlottesville, VA
| | REAL 80+ CC Happy Times! HI All,
I was just looking at an old partially disassembled engine today and was thinking of a low $$ way to increase displacement and power...
Recasting an entire cylinder would probably be expensive so I thought to myself....what about just making a spacer that fits on the bottom of the cylinder jug and make a new connecting rod (of course slightly longer studs would be needed too).....the longer stroke will add displacement and torque....how many additional cc would 1/8 more give you?....How about 1/4 inch more?...Of course hopefully there will be enough clearance inside the crankcase?
I know connecting rods can be made of aluminum so machining a rod shouldn't be too difficult....of course the balance issue comes into play BUT since we are using the same piston maybe it won't be too far off?
Minor porting for the additional displacement may be necessary but then again maybe not.....same fuel / air mix with a longer stroke should yied tons of torque...
So what do you think? Seems like it wouldn't be too expensive to get more from our engines!
Andrew |
07-12-2008, 09:46 PM
| | Motorized Bicycle Builder | | Join Date: Feb 2008
| | Re: REAL 80+ CC Happy Times! A longer rod wont give any more stroke.
You need a reground crank for that. |
07-12-2008, 09:59 PM
| | Re: REAL 80+ CC Happy Times! Wouldn't that actually lower the compression??.......
__________________ There are only 10 kinds of people in this world. Those that understand binary and those that don't............
Become a Forever Family, it'll change your life. http://www.galtx.org/ http://bdconner.com |
07-13-2008, 12:29 AM
|  | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: Santa Cruiz, CA
| | Re: REAL 80+ CC Happy Times! Stroke is not relative. It is dependent on the length of stroke from TOP to BOTTOM.
If you increase the top by the same amount as you increase the bottom, you haven't increased the stroke or anything else, except a bit of metal. Now, if you say you can increase the height in which the piston travels, yet maintain the lowermost point the piston travels...now we're talking! (Of course, you'd need to modify the crankshaft and case to match the increased throw...and oh yeah...don't 2-strokes need super-precise intake/exhaust porting! |
07-13-2008, 07:07 PM
| | Re: REAL 80+ CC Happy Times! Hmmmm....messing with crankshaft sounds expensive....Wasn't there something about altering an engine's power characteristics by messing with rod length and piston heights WITHOUT messing with crankshaft throws..I wonder if we added the spacer at the bottom of the cylinder, used a longer connecting rod, and made a custom piston if that could accomplish anything power wise?
Andrew |
07-13-2008, 08:17 PM
| | Re: REAL 80+ CC Happy Times! Assuming no changes made to porting(which are critical in regards to piston positioning) the only way to increase it as you're alluding to is to increase the bore. In a car, one would bore out the cylinders and slap in wider pistons. From what I understand, these engines have just enough metal for the existing pistons. If one was knowledeable about custom manufacturing their own pistons to match their own crankcases...well, now we're talking about scratchbuilding. |
07-13-2008, 08:22 PM
| | Re: REAL 80+ CC Happy Times! I know a lot of karting guys will use a longer rod and shorter piston to change the rod angle. They do that so they can turn higher rpm and a little less likely to make a viewing port on the side of the block.............................
07-15-2008, 05:53 PM
|  | Custom Builder / Dealer | | Join Date: Mar 2008 Location: Venice Beach, CA.
| | Re: REAL 80+ CC Happy Times! I wouldn't do that to your engine!!! The intake & exaust timing are controlled by the port heights... if you mess with rod length & piston height, you will change the timing!! (& probably not for the better!!)
I would look into boring the cylinder & finding a bigger piston,(with the same height)... but then you have to re-balance the crank! |
07-15-2008, 08:46 PM
|  | Genius Visionary | | Join Date: Jan 2008 Location: Ashtabula county, Ohio
| | Re: REAL 80+ CC Happy Times! No to mention boring the cylinder will destroy it since they are nikasil liners.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 02:47 PM. | | |
