| Sponsors
| | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Quiet Needed!! Loud expansion chamber PIPE Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. You guys probably saw this post coming 5 miles out....or rather you heard me coming :bike:
I installed a ...  | |
06-09-2008, 01:07 PM
| | Quiet Needed!! Loud expansion chamber PIPE You guys probably saw this post coming 5 miles out....or rather you heard me coming :bike:
I installed a Pocket Bike expansion chamber this weekend.
I'm done gushing about my new power (it's still amazing), now the reality of the new expansion chamber is setting in……this sucker is LOUD. I wouldn't mind if I lived in the country - but I'm afraid the neighbors will start griping. Sorta .226 machine gun fire - crack-crack-crack - slow idle is nice though. (Added beni, it even idles better than originally, surprisingly I had to back the idle screw off quite a bit) When idling it is not on the pipe - just flowing through, so to speak.
The source of this exhaust noise appears to be twofold. Per my ear nearby, part of it is my fittings up front - they are fairly loose. I can easily take it apart. Maybe expand the male half to make snug slip fit, on the male (steel) manifold I can use some exhaust system sealant goop, because that stubby steel flanged nipple could be tough.
The other is the so called silencer (it should be called a loudener) - it's not removable (welded to the pipe after the chamber itself). The silencer "cover" is riveted in place. To improve this one could be interesting. Drill out the rivets and stuff it? (I think it's empty inside). OR cut it off and attach an new quiet one?? Where is a silencer source? What will be left to clamp onto will be about 1" of or so 5/8"-7/8" OD stub. (I need to measure it)
I guess I'm open to any ideas as well as help finding a new silencer.
Thanks!
P |
06-09-2008, 01:27 PM
|  | Master Motorized Bicycle Builder | | Join Date: Jan 2008 Location: Arizona Bullhead
| | Re: Quiet Needed!! Loud expansion chamber PIPE A chamber in resonance is extremely loud HUH.
Stuff aluminum screen material in the silencer after you remove the rivets. then use screws to seal.
If your pipe to the chamber is leaky expand the ends of the tubes by hammering in a tapered plug, then a trial fit.
Lather , Rinse, Repeat. |
06-09-2008, 01:34 PM
| | Re: Quiet Needed!! Loud expansion chamber PIPE Quote:
Lather , Rinse, Repeat. | A little louder I expected. Aluminum screen material? Interesting idea. I was thinking steel wool or fiberglass batting.
No need to hammer - I have a 20 ton press.  |
06-09-2008, 01:43 PM
Originally Posted by Pablo A little louder I expected. Aluminum screen material? Interesting idea. I was thinking steel wool or fiberglass batting.
No need to hammer - I have a 20 ton press.  | I use aluminum screen in my homemade mousecan style muffler.
I did NOT like the POP POP POP. when I cut off my baffle.
I got a nice power increase and a pleasant rumbly sound.
I used a 1,5 to 2 inch exhaust pipe 45 degee I think,
Stuffed with aluminum screen material.
A length of plumbers tape and a 2 inch 14-20 bolt hold the end of the pipe and keep the screen in.
You are going to use a 20 ton press for finish work?
06-09-2008, 01:49 PM
| | Re: Quiet Needed!! Loud expansion chamber PIPE Sweet! Yeah that pop-pop-pop gets old real fast. It's not so bad at 40 mph, but.......I'm sure it is to observers.
I'll need to get some real Al screen. All I have is fake new age kind. That would melt and get nasty. |
06-09-2008, 01:52 PM
Originally Posted by Pablo Sweet! Yeah that pop-pop-pop gets old real fast. It's not so bad at 40 mph, but.......I'm sure it is to observers.
I'll need to get some real Al screen. All I have is fake new age kind. That would melt and get nasty. | When I top out the only thing I can hear is the air rushing past my ears. |
06-09-2008, 01:56 PM
Originally Posted by spad4me You are going to use a 20 ton press for finish work? | No, to expand my copper fitting male ends:
For a tighter fit. I'll need to rig a mandrel, etc,  |
06-09-2008, 02:07 PM
| | Re: Quiet Needed!! Loud expansion chamber PIPE Ok!
Nice pipe. |
06-09-2008, 03:52 PM
| | Re: Quiet Needed!! Loud expansion chamber PIPE Norman makes some awesome silencers. He presses out some cups and rolls a tube and sticks them in it. Maybe we can take some pictures or maybe he can tell you how he does it. It really quietens it down. Just ask Cruiser......................
__________________ There are only 10 kinds of people in this world. Those that understand binary and those that don't............
Become a Forever Family, it'll change your life. http://www.galtx.org/ http://bdconner.com |
06-09-2008, 03:56 PM
| | Re: Quiet Needed!! Loud expansion chamber PIPE Hail Normanator, hale Norman!!  | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 11:59 AM. | | |
