Proper clutch usage
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. My experience driving with a clutch is pretty limited so I wanted to clear some things up. When is the ...
Old 10-19-2008, 12:28 PM
Default Proper clutch usage
My experience driving with a clutch is pretty limited so I wanted to clear some things up. When is the proper time to pull the clutch lever on my bike? Does that "engage" or "disengage" the clutch. I'm assuming I should:
1. pull the lever when at a complete stop
2. pedal a little to start off
3. release the clutch (slow? or fast?) and give it some gas to go on my way again
What about when coasting down a hill or flat land, do I pull the clutch lever? When I'm coming to a stop at what point should pull the lever, just before the stop?
Feel free to treat me like a complete idiot in your reply. I've been getting along just fine with my test runs but I don't want to be stressing my engine and not knowing it
Old 10-19-2008, 01:15 PM
Finfan's Avatar
Default Re: Proper clutch usage
Pulling the lever disengages the clutch. If you want to stop you pull the lever and start braking. Otherwise your brakes will be working against the engine.
For starting with the engine on I try to pedal up to speed then slowly ease in the clutch until it catches. Pop it too fast and you might stall. Keep pedaling until you can't keep up with the engine.
It is a matter of "feel" and practice. Don't worry, you'll figure it out quickly enough. Enjoy the ride!
-and-
I'm not lost, I'm exploring!
Old 10-19-2008, 10:21 PM
old motorbike's Avatar
I just installed the shift kit and can start off in 1st gear from a start, but still take it easy on the clutch and pedal to get moving first.
