Problem with the Clutch
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Everything was working fine, then all of a sudden my clutch will not engage. I removed the housing from in ...
Old 09-27-2008, 12:31 PM
Motorized Bicycle Apprentice
Default Problem with the Clutch
I removed the housing from in front of the chain gear and looked at the pin that normaly engages the clutch. Try as I might I could not get it to push in. (even with the help of a rubber mallat).
When I look inside the hole I think I see a smaller pin, but I am not sure.
Can someone take a look at the pictures and give me some advice. I really don't want to break open the engine housing unless I have to.
Thanks!
-Stephen
Old 09-27-2008, 01:59 PM
DragonB's Avatar
Smile Re: Problem with the Clutch
im pretty sure your gonna have to take it apart, i cant see what the problem is just from those pics... besides, its a huge issue and needs to be resolved correctly for your own health!
Old 09-27-2008, 04:29 PM
misteright1_99's Avatar
Default Re: Problem with the Clutch
In front of the rod is a ball bearing. Get a magnet to get it out. Shoot some grease in there, insert the ball, more grease then the rod, then more grease on the clutch arm, put it back together and retry. It is also a good idea to unscrew the clutch cable adjustment anchor and pump some grease in there. I use a grease hose with a needle to get it there.
Old 09-27-2008, 09:33 PM
That did it. Thank you very much!
Old 09-27-2008, 10:25 PM
Happy to help, as many here, have helped me....
Advertisers
