| Sponsors
| Our Forums | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Problem! Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Problem
The last time my bike was running was the other day when I was running WOT then my chain ...  | |
11-27-2009, 04:09 PM
|  | Motorized Bicycle Elite Member | | Join Date: Oct 2009 Location: Tucson, ZonieLand
| | Problem! Problem
The last time my bike was running was the other day when I was running WOT then my chain snapped in half and the engine shut off. I also herd a loud sound that sounded like a pistol as it happened. well I fixed my chain and checked my plug and it seems pretty oilily. I fired her up and Let her warm up a few. Gave her a rev and it was boggin. let her warm up some more and the bogging went away. So I peddle, let the clutch out and she was JULTING back and forth really bad. The C clip is 3 down from the top.
I checked for air leaks using my eyes and wd40. What could of happened to her the day she was last running?
I hope to resolve this problem before tomorrows Rally. Any help would be much appreciated. |
11-27-2009, 04:16 PM
| | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: ridgway colorado
| | Re: Problem! if your satisfied that you have no air leaks check all the wiring i have had recent probs with kill switches but check everything fuel flow etc |
11-27-2009, 04:18 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: Top of NY
| | Re: Problem! try cleaning your airfilter and check your chain again. |
11-27-2009, 04:45 PM
| | Re: Problem! Well I lowered the C-clip one notch and she ran better without any julting. When I put the slide back in how far down is it supposed to go. The slide stops about 1/8" to the bottom. |
11-27-2009, 05:23 PM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: Decatur,IL
| | Re: Problem! make sure the slide's groove is lined up with the small nipple inside carb and it should fall in all the way. as for the chain breaking what is the root cause of chain breaking in the first place? old chain, missing master link,or break for some reason, did it fall off rear sprocket? too much slack? and what was the "pistol" noise? chain whipping around? motor break or frame break? and then what caused the motor to die? chain jam? electrical? or from chain breaking? always make sure their is a master link in place and is in the right direction! and never be greedy on the chain lube! for a chain to break, something bad happened and is mis-aligned! check your ride carefully, your life depends on it!
__________________ FileStyleCycles |
11-27-2009, 06:06 PM
| | Motorized Bicycle Elite Member | | Join Date: Aug 2008 Location: Long Island, NY
| | Re: Problem! That pistol sound was probably a back-fire. |
11-27-2009, 06:15 PM
| | Re: Problem! Thanks for all that filestyle. Im am new too all all this stuff. But that day I was going on a long ride and did a full inspection of the bike before I left. I didnt run it too hard through the 16 mile ride.
I havent checked the electrical parts since I put it together.
I fixed the chain but I didnt use the master link. I just used a cheap chain breaker from walmart (Dont waste your money it broke within ten minutes) to slide the pin right in. Should I use a master link??
Anyway. It runs but At very slow speeds I get the Julting back and forth motion and also when I go over 25mph. I just put a new NGK B6HS. I lowered the need. c clip is one down from the top and im running 32:1. |
11-27-2009, 06:25 PM
| | Re: Problem! did you check your engine mounts and bike frame? |
11-27-2009, 06:31 PM
| | Re: Problem! Just checked the frame and there doesnt seem to be any cracks and also the mounts are securely fastened. |
11-27-2009, 06:52 PM
| | Re: Problem! sounds like your airfilter is cloging up,try taking off the airfilter and housing and take it out for a run and post the results. dont forget to clean the filter and put it back on after. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 09:43 AM. | | |
