FAQ
Members List
Calendar
Mark Forums Read
Spookytoothcycles.com Bicycles, motors, and accesories
Pablo's Lubricants
ThatsDax.Com HOME OF THE TITAN XC 50CC 4 STROKE
Shifting Kits For Motorized Bicycles & More
80CC & 50CC
ENGINE KITS
ON SALE NOW!
Motorized Bicycle
Motorized Bicycle General Discussion
Piston Arm?
User Name
Remember Me?
Password
Topics on
bicycle engine kits
, help articles, repair and modifications for your
motorized bicycles
Piston Arm?
Discussion at
Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion
forum. Question 1: What is this part called? Question 2: Mine has about 3 to 5 mm play left to right, ...
Page 1 of 2
LinkBack
permalink
06-23-2008, 03:44 PM
MrLarkins
HS Math Teacher
Piston Arm?
Question 2: Mine has about 3 to 5 mm play left to right, is that normal or excessive?
http://www.youtube.com/watch?v=MOQuj2XukHc
2
permalink
06-23-2008, 03:50 PM
Pablo
Re: Piston Arm?
Rod. Piston rod.
http://oilslubesfilters.com/
AND NOW
http://www.sickbikeparts.com/
3
permalink
06-23-2008, 03:52 PM
MrLarkins
HS Math Teacher
Re: Piston Arm?
is it suppose to be tight, or have some wiggle to it?
4
permalink
06-23-2008, 04:36 PM
misteright1_99
Re: Piston Arm?
The technical term for it is "connecting rod"..
5
permalink
06-23-2008, 04:50 PM
Pablo
Re: Piston Arm?
Originally Posted by
MrLarkins
Supposed to move with the piston, but have very mininal side to side movement....what ya mean by "wiggle"?
AND NOW
6
permalink
06-23-2008, 06:15 PM
MrLarkins
HS Math Teacher
Re: Piston Arm?
by wiggle, i mean side to side movement...about 3mm to 5mm
7
permalink
06-23-2008, 06:22 PM
Pablo
Re: Piston Arm?
5mm Sounds like a lot - I don't know what the spec is - PM Norman to check this thread!
AND NOW
8
permalink
06-23-2008, 08:54 PM
Norman
LORD VADER Moderator
Re: Piston Arm?
I have no specs. on these engines but I'm guessing you should be ok. You don't see any metal flakes or metalic particles inside the crankcase do you?
That would be caused by a needle bearing trashing on either the wrist pin or on the crank end of the rod.
what you had outlined in red is the wrist pin end of the connecting rod.
You will have some side to side play on both the wrist pin end and the big end of the rod and as sorry as these engines are made probably some circular twist as well.
It looks like either you have a needle bearing wrist pin or else you pressed out the writ pin bushing.
Are you having a problem or hearing a strange noise with this engine?
norms-iron-works.tripod.com
9
permalink
06-23-2008, 09:07 PM
Pablo
Re: Piston Arm?
I think the problem starts here:
80cc Mystery
AND NOW
10
permalink
06-23-2008, 09:09 PM
Pablo
Re: Piston Arm?
Here's the video of his beast:
http://www.oskgaming.com/downloads/video.wmv
= 2.79MB
AND NOW
Page 1 of 2
Snapped All Thread Mounting Bolt
Spark Plug Question
Show Printable Version
Email this Page
Linear Mode
Switch to Hybrid Mode
Switch to Threaded Mode
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
vB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
Trackbacks
are
On
Pingbacks
are
On
Refbacks
are
On
06:49 PM
Miner Skinz.com
Advertisers
Search Engine Optimization by
vBSEO
3.1.0
Contact Us
Archive
LinkBack
LinkBack URL
About LinkBacks
Bookmark & Share
Digg this Thread!
Add Thread to del.icio.us
Bookmark in Technorati
Furl this Thread!
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
