| Sponsors
| Our Forums | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Past the power curve ? Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. I've got a stinger sd"80cc" motor on my board tracker. Have run about a gallon of gas through it @16 ...  | |
11-19-2009, 06:03 PM
| | Motorized Bicycle Newbie | | Join Date: Oct 2009 Location: wilmington nc
| | Past the power curve ? I've got a stinger sd"80cc" motor on my board tracker. Have run about a gallon of gas through it @16 to 1.I just swithched to synthetic motorcycle racing oil @ 50 to 1. Engine makes real good power under load but when bike is atwide open throttle and cruising ti kind of fallsoff and surges . throttleback and put load on it pulls hard again. I have 44 tooth sprocket. Should I goto a smaller rearsprocket to keep it in the power band better. My friends bike with 80cc slanthead motor and I think36 tooth rear sprocket seems to pull all the time even at cruise wide/open. Plug is fresh ngk and nicegrey/tan color after hard run. Anythoughts |
11-19-2009, 06:48 PM
| | Re: Past the power curve ? Re-jetting the carb a hair smaller has always fixed this problem for my bikes!  |
11-19-2009, 06:53 PM
| | Motorized Bicycle Elite Member | | Join Date: May 2008
| | Re: Past the power curve ? Ditto! Same for me. |
11-19-2009, 08:23 PM
|  | Motorized Bicycle Elite Member | | Join Date: Apr 2009 Location: granbury
| | Re: Past the power curve ? Quote:
Originally Posted by Venice Motor Bikes Re-jetting the carb a hair smaller has always fixed this problem for my bikes!  | What size drill bit would I use to do this????Resoder it and then redrill the hole????I think I will just wait until SBP gets there carbs back in stock....
John-John
IF I CANT FIX IT,IT ISN'T BROKEN!....ummmmmmm so I thought....
11-19-2009, 10:40 PM
| | Re: Past the power curve ? Just go to a hardware store that sells tiny 'jewlers' bits; find the one that fits in your jet perfectly, & then buy the next two smaller sizes!! I think #70 is what the stock jet is?? |
11-20-2009, 03:21 AM
| | Re: Past the power curve ? Another thing to check/try is bending the float tabs up a hair - could be just a starvation issue... It was with mine anyway  |
11-20-2009, 07:48 AM
| | Re: Past the power curve ? ....or a loose jet.
#70 is .028"
#71 is .026"
#72 is .025"
I got a whole set off of ebay for 6.99 shipped.
11-20-2009, 09:30 PM
|  | Motorized Bicycle Elite Member | | Join Date: Aug 2009 Location: Howell, New Jersey
Originally Posted by fall_down_stand_up What size drill bit would I use to do this????Resoder it and then redrill the hole????I think I will just wait until SBP gets there carbs back in stock....
John-John | Spooky will have the CNC Carbs on day after thanksgiving. |
11-23-2009, 06:48 PM
| | Re: Past the power curve ? Ive tried your suggestions about going to smaller jet size . my original was in between #70 and # 71. TI have a metal lathe and can make my own jets ,wanted to save the original intacked. went down .004" problem seems a slight bit better but much. I'm not sure this thing is fukky broken in yet, I'm going to run it more and see what happens. even after going down in jet size plug still looks just a touch rich. How long does it take to fully break in one of theses motors? thanks for all the help. I'm stuborn and wont quit until it runs right! |
11-23-2009, 08:37 PM
Originally Posted by rob king Ive tried your suggestions about going to smaller jet size . my original was in between #70 and # 71. TI have a metal lathe and can make my own jets ,wanted to save the original intacked. went down .004" problem seems a slight bit better but much. I'm not sure this thing is fukky broken in yet, I'm going to run it more and see what happens. even after going down in jet size plug still looks just a touch rich. How long does it take to fully break in one of theses motors? thanks for all the help. I'm stuborn and wont quit until it runs right! |
Don't try to re-jet your carb until you've fully broken in the engine!!! (about 4 gallons!)
It will start running different as it breaks in! (& you'll have to re-jet again) | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 03:29 AM. | | |
