| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | ordered my slant 80 head! Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. ccmotobikes.com | Cruising by the sea! has the 80cc slant heads. $22.95 plus $5.00 shipping. He said in ...  | |
05-19-2009, 07:08 AM
|  | Motorized Bicycle Elite Member | | Join Date: Oct 2008 Location: alabama
| | ordered my slant 80 head! ccmotobikes.com | Cruising by the sea! has the 80cc slant heads. $22.95 plus $5.00 shipping. He said in an email that the average top end gain on the test bikes was around 6 mph. also, he said that the gain on the bottom end was like pedaling to take off was almost not needed. We'll see. |
05-19-2009, 07:26 AM
| | Re: ordered my slant 80 head! Zoom bikes was a little less, $21.45 total delivered.
I have not taken mine up that high yet....but I doubt I will see 46 mph. They look like they are the same heads. Hmm....mine seems to be 100% bottom end gain (nice), but I suppose my bike was fairly well tuned before. |
05-19-2009, 08:14 AM
| | Re: ordered my slant 80 head! HEY PABLO, Did you use two head gaskets? also, this is what he sent in an email. he said I would need two gaskets.
We suggest the NGK BP6HS 7331 spark plug
This plug has a longer thread causing the compression chamber to decreases
in volume. Just like the slant heads decrease the compression volume, this
plug gives you a compression boost that equals more power and torque.
Usually spark plugs do not gives performance boost spark wise in this case
it's all about the compression ratio. It is a definite performance upgrade
that is as essential as the slant head
05-19-2009, 09:28 AM
| | Re: ordered my slant 80 head! HEY TOKER! Who is "he"?
TWO? No I didn't use two head gaskets. I guess that would a be (silly) option if contact was a problem. I'd worry about sealing.
Interesting on the BP5HS plug. From our site: Quote: |
A true high performance plug for an actual increase in performance. Rarely would we claim that a spark plug will increase performance, but we know if the original plug is defective, getting a proper plug will of course help. The NGK BP6HS goes a step beyond that, with an extended tip, it centers the spark in the combustion chamber and actually displaces volume, effectively increasing compression ratio. An added benefit is with the protruding electrode the plug is even more foul proof than the standard B6HS. Also, the 6 is a cooler heat range for those hard max throttle runs. A really great spark plug for your modified 67cc engine.
05-19-2009, 05:25 PM
| | Re: ordered my slant 80 head! "he" is the guy from ccmotobikes. So if I use BP5HS i can use just one head gasket? |
05-19-2009, 05:40 PM
| | Re: ordered my slant 80 head! Quote:
Originally Posted by toker_ace "he" is the guy from ccmotobikes. So if I use BP5HS i can use just one head gasket? | OK. IF the head is the same and IF your engine is the same as mine, no need for two gaskets. But I know some engines have "contact" issues.
BP5HS and BP6HS protrude the same amount. |
05-19-2009, 11:01 PM
| | Motorized Bicycle Newbie | | Join Date: Apr 2009 Location: Texas
| | Re: ordered my slant 80 head! Yeah most of the new engines don't have contact problems so that's why some people with older engines opt out for double gaskets. Let us know what improvements you see toker_ace! |
05-20-2009, 06:34 AM
| | Re: ordered my slant 80 head! I hate to tear into my new grubee because it runs great and has lots of power, but more power is even better. What should i torque the head bolts too? |
05-20-2009, 06:40 AM
Originally Posted by toker_ace I hate to tear into my new grubee because it runs great and has lots of power, but more power is even better. What should i torque the head bolts too? | 15-16 ft. lbs. IF you have real nuts, not acorn nuts. |
05-20-2009, 07:25 AM
| | Re: ordered my slant 80 head! ACORN NUTS! LOL. I thought you were being smart at first. lol. I got real nuts. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 06:08 AM. | | | Sponsors
