Which one??
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. OK so this may be a dumb question but do you use two stroke oil or regular motor oil to ...
Old 10-10-2008, 11:17 AM
Motorized Bicycle Apprentice
Default Which one??
OK so this may be a dumb question but do you use two stroke oil or regular motor oil to mix with the gas?? if regular which weight??
Old 10-10-2008, 11:24 AM
Saddletramp1200's Avatar
Default Re: Which one??
Never use reg. oil in a 2 stroke motor. It was not made for that. 2 stroke oil is what you need. Ams OIL is what I use. New motor 30:1 broken in motor 20:1
No matter where you go, or what you do, there Ya' are!
Old 10-10-2008, 11:27 AM
deacon's Avatar
I think you have those ratios backwards tramp, I use walmart 2stroke oil. 20 parts gas to 1 part oil for the first couple of tanks then 32 parts gas to 1 part oil is what my engine instructions (such as they were) recommended.
visit my blog for Riding in the hood,... The home brew bike journal....http://frictiondrivebicycles.blogspot.com/ The deacon's fiction
Old 10-10-2008, 11:57 AM
im with deacon on this . 20:1 for break-in, 32:1 after that. and by the way , you can use motor oil for 2 stroke oil. non-detergent 30w. but you must run about twice as much oil, 32:1 2stroke oil= 16:1 30w.
Old 10-10-2008, 03:42 PM
Ok got everything on good and tried to give it a go but no fire. do you
1.hold the clutch in 2. Peddle, 3. Let go and give it the throttle??? bc if the clutch isnt held in the tire wont turn.
Old 10-10-2008, 04:29 PM
OSCAR383's Avatar
You Forgot A Step .
1. Pull In Clutch
2. Peddal
3. Release Clutch
4. Give Her Some Gas AND GO
5. :d Grin Like A Fool
NUMBER 5 IS IMPORTANT
MEASURE ONCE AND CUT TWICE.......WAIT A MINUTE
Old 10-10-2008, 04:35 PM
velardejose's Avatar
Hi
Close the choke before starting
Peace
Old 10-11-2008, 04:40 AM
fairracing31's Avatar
1. Open the fuel valve. Small lever pointed down with fuel line is in the open position.
2. Depress the small round cap plunger, ( Tickle button ), to prime carburetor. Located on left side of the carburetor next to the idle adjustscrew.One or two times is enough.
3. Lift choke lever to the upward position. This is the small lever on the right side of the carburetor. All the way Up the choke is on. All the way Down the choke is off. Move progressively downward to off position during engine warm up period.
4. Pull the handlebar clutch lever inward, to disengage the engine from the rear wheel.
5. Pedal; 7-10mph
6. Let out the clutch lever all the way out and continuing to pedal. The result is a direct engine hook up with the rear wheel via chain and sprocket and the engine will now start spinning, Pedal until motor starts. Accelerate slowly at first..
7. Twist throttle to increase speed, reverse twist throttle to decrease speed. To stop, disengage clutch and apply brakes. To accelerate, pedal and release clutch while opening throttle.
8. Adjust choke to the smoothest engine running position.
9. After warm up push choke lever all the way down. If engine races too fast, or too slow, pull clutch lever and lock in the notched catch, stop and adjust engine rpm.
If the rpm needs adjusting, turn the idle adjust screw (left side of carburetor) in or out slowly to obtain the proper idle speed of about 1400 rpm
11. To stop the engine, push Kill switch and turn off gas valve at tank.
Advertisers
