Originally Posted by doublezo first off the search function on this site doesnt work too well, i looked for my anwser . there is so much info on gas oil mixture and im confused. i would like to know the proper mix for my motor after breakin. ive seen 25:1 20:1 36:1 and 32:1 actually ive seen 40:1 also. im using a good quality oil. thanks in advance, brian. |
32:1 is proper starting spot for a good oil. If too oily you can back off a bit. Engine isn't that picky, but it's best to stay with one ratio once you have it dialed in, or you may end up tuning again.
