Re: noise after clutch engaged Part of the noise comes from the reduction gears in the right side of the engine.
Make sure you open the cover and put some grease on them, about once every other week, depending on how you ride it. Do not use oil, because the clutch is next to them.
As those two gears wear out with time and use, the noise should be reduce.
See You in the Road !!! |
