FAQ
Members List
Calendar
Mark Forums Read
To be a sponsor
Contact Us
50 & 80cc RAW MOTOR SALE, FREE S/H, 6 MONTH WARRANTY!
Grubee Skyhawk GT5's In Stock!
Shifting Kits For Motorized Bicycles & More
1-888-KIT-BIKE BIKEMOTORKIT.COM
Manic Mechanic
Machined parts for
Motored Bikes
FireBelly Cycles
AUSTRALIA’S Home for Bicycle Motors, Parts & Chainless Bicycles
New, Fully Assembled Motored Bicycles
Stock Market Cats
Alternative Energy
Busco A Dios
Motorized Bicycle
Motorized Bicycle General Discussion
No spring back in throttle
User Name
Remember Me?
Password
Topics on
bicycle engine kits
, help articles, repair and modifications for your
motorized bicycles
Discussion at
Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion
forum. Anyone there for some help?...
LinkBack
permalink
09-19-2009, 07:42 PM
salserod
2
permalink
09-20-2009, 12:42 AM
bandito
Re: No spring back in throttle
I havnt seen any other problems with the stock springs in any threads so Ill assume you have a problem in your twist/lever throttle being too tight, your cable having a too sharp a bend in it or some thing sticking in the carb/linkage. Make sure you lube every thing with wd40 and every thing is free to move to let the spring do its job.......make sure the cable housing ends arent crimped too tight to restrict the movement of the cable through them also. Could just be way out of adjustment too.
3
permalink
09-20-2009, 01:12 AM
salserod
Thanks for the reply. I did some more investigating and I believe the problem is in the carb. I am new to this so please excuse my ignorance. There are no and the cable is moving freely but when I turn the throttle it does not spring back to idle position. So I took off the carb to see what was going on. This is where I am lost. There is a spring inside a brass sleeve and the cable is inside the spring and it goes through the slot in the brass sleeve. There is a needle that goes into a hole. It seems as if the brass sleeve is too tight and does not move very easy. Should it be like this? Also, when it is at full throttle the pin should be out of the hole correct. I am not sure how that mechanism works. Thanks.
4
permalink
09-20-2009, 01:20 AM
GearNut
The carburetor slide should be ablt to slide up and down very easily. Check the slide hole on the carburetor to see if it is out of round.
Some folks have needed to sand the slide a teeny bit smaller in diameter with fine sandpaper.
Also overtightening the slide cap on the carburetor is a no no. It will distort the slide hole.
5
permalink
09-20-2009, 01:29 AM
azbill
there is also a little guide 'pin' inside of the carb body. it lines up with the slot in the slide
Bill
www.ezmotorbike.com
azgrampa@gmail.com
6
permalink
09-20-2009, 08:41 AM
Sydneysider
Most of the time I found they dont always go back to close throttle position but once the engine is started, the vibration fixes that, the twist throttle wears in and springs back normally after a few runs..
I Need Help Deciding Fassssst!
UPS Store
Show Printable Version
Email this Page
Linear Mode
Switch to Hybrid Mode
Switch to Threaded Mode
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
vB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
Trackbacks
are
On
Pingbacks
are
On
Refbacks
are
On
09:52 PM
Miner Skinz.com
To be a sponsor
Contact Us
80CC & 50CC
ENGINE KITS
ON SALE NOW!
Spookytoothcycles.com Bicycles, motors, and accesories
Use Coupon Code
BMSKYHAWK30
to get $30 off any Grubee SkyHawk Kit!
ThatsDax.Com HOME OF THE TITAN XC 50CC 4 STROKE
Fallbrook Technologies NuVinci® Drivetrain
Frames with gas tank inside the top tube
StriderRides.Com motorized bicycles
-- English (US)
-- Español (ES)
Search Engine Optimization by
vBSEO
3.1.0
Contact Us
Archive
LinkBack
LinkBack URL
About LinkBacks
Bookmark & Share
Digg this Thread!
Add Thread to del.icio.us
Bookmark in Technorati
Furl this Thread!
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
