Re: Newbie needs help on how to drive The petcock is "on" when the lever lines up with the fuel flow/line direction.
Try partial choke (3/4 up).
I would as some have advised, check for spark, and if none is found , disconnect the kill switch. They usually last five minutes before they go bad, or they never go bad. I have had 4 of 6 that were junk.
