new to the board, have a few noob questions i'm sure have been answered.
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. hi guys, gals. new to the forum. my name is leigh and i'm up here in london ontario (canada) ...
Old 05-29-2009, 02:29 AM
Default new to the board, have a few noob questions i'm sure have been answered.
hi guys, gals. new to the forum. my name is leigh and i'm up here in london ontario (canada) been building bikes for sometime, but this is my first moped.
i've been building an indian inspired boardtrack racersince last year. i still have alot of work to do (including a custom stainless tank,) but i'm itching to ride this beast,
heres the bike last halloween. thats the tank i still have to finish.
well i've had a change of heart since then and the build has taken on a new dirrection.
heres what it looks like now and brings me to my first question. mounted the kit tank just to get it running
i've dropped down to a 24" wheel with a vintage set of uniroyal chain tread tires. dirrections(or should i say "indications"lol indicate this motor should work on most 26"/28" bikes. is there any reason i shouldn't use it on a bike with 24" tires?
now, no self respecting indian boardtrack racer would sport plastic parts, so i ditched the cheap throttle and used an old set of plated brake levers for the throttle and clutch.
they have enough travel to do there job's. i do however need to replace the kill switch (with something metal i hope) thought about a small toggle switch. was hoping to see some pic's of your custom/replacement kill switches. post away (please and thx)
next question, coaster brakes. i've read ad's that say "new improved sprocket more room for coaster brake arm" and i've also read warnings against using them. mine is currently fitted with a coaster brake. am i askin for trouble? as long as i use the clutch before the brake, are there any dangers i should know about?
last question (fo now) i have an assorted pack of gaskett materials. now my head looks alittle warped and seems it might leak. gonna change out all the gasketts, but i was wondering
which material should i use for the head gaskett? there cork,cork-neopreme,neopreme,rubber,compressed paper???? in the pack.
thx for all your help, i'd love to be tooting around this weekend.
Old 05-29-2009, 01:38 PM
Default Re: new to the board, have a few noob questions i'm sure have been answered.
Someone else will come along soon to answer your first two questions but I can help you with the last.
Do not use cork.
It sounds like you bought the same sampler pack I did. The only one that has held up worth a darn is the rubberized high heat fibre (or something along those lines) and even that got brittle after a hundred miles or so. I don't know if it was about to fail but it was hard as a rock when I took the parts off to track down another problem. I haven't found an appropriate replacement available at the auto parts store but a very generous someone is sending me some "super gaskets". Hopefully someone else will chime in but I just wanted to warn you...
...do not use the cork.
Old 05-29-2009, 02:40 PM
fairracing31's Avatar
You can use 24" wheels, you may need to go with a smaller sprocket to obtain the same speed with a 26" wheel.
I used only a coaster brake for years and thousands of miles with no problems. But I will admit it is not the best stopping power. I have since added a front brake as well for better stopping.
I use a atv kill switch on mine, but you can also use a toggle switch.
Old 05-29-2009, 02:51 PM
Cabinfever1977's Avatar
my coaster brake works better than any regular brake i ever had.
i like the idea of a brake lever for a throttle because the stock throttles dont like to return,does anyone know if the throttle cable end will fit a brake lever? and do i need a spring on the lever so it snaps back?
Old 05-29-2009, 03:11 PM
Finfan's Avatar
When it comes to brakes more is better. I added a set of side pull brakes to my ride as a back up to the coaster brake. Just in case.
-and-
I'm not lost, I'm exploring!
Old 05-29-2009, 04:45 PM
thx guys. old indian boardtrack racers didn't have much in the way of brakes (if any at all)
who needs em! (kidding of course)
as for the throttle/brake, i had to use a standard brake cable and crimped a stop on the carb end.
the original just wouldn't work (big metal bolt on one end/too much exposed cable for the brake lever to work.)
you can use the original cable but you will have to cut off the stop on one end, get rid of the bolt,cut of the excess and re-crimp a stop. or at least that was my experiance.
Old 05-30-2009, 03:43 AM
hey look at that, pictures yeah!
Old 05-31-2009, 07:08 AM
btw whats the best way to wire the kill switch.
should i attach the black wire to the others, or ground it out on the frame? does it matter?
thx
  #9 (permalink)
Old 05-31-2009, 04:47 PM
i grounded it to the frame/front engine mount. any where theres a small bolt and not a lot of heat.
  #10 (permalink)
Old 07-21-2009, 04:21 PM
since my last visit i have done alittle more work on the indi-ain't.
mounted my killswitch
finally got around to finishing the custom ss tank.
even fashioned an alum number plate. (sorta doubles as a chain/sprocket guard.)
picked up a couple cool stickers
its just about ready for paint.
just wanted to share, enjoy.
