***new Bike, Need Your Opinion***
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. bike is done. however, the throttle is wide open and does not allow me to stop it. i think there ...
Old 07-27-2008, 02:14 PM
Motorized Bicycle Builder
Default ***new Bike, Need Your Opinion***
bike is done. however, the throttle is wide open and does not allow me to stop it. i think there might be a bind in the throttle cable which is not allowing the throttle to close. what do you guys think?
new-bike-need-your-opinion-img_7521.jpg  new-bike-need-your-opinion-img_7522.jpg  new-bike-need-your-opinion-img_7523.jpg  new-bike-need-your-opinion-img_7524.jpg  new-bike-need-your-opinion-img_7525.jpg
Old 07-27-2008, 02:32 PM
Default Re: ***new Bike, Need Your Opinion***
That is the most likely reason. Check to make sureb the slide in the carb runs all the way up and down. You should be able to find the problem without too much trouble.
Old 07-27-2008, 02:36 PM
so i think i should free up the throttle cable i think there is too many bends in it.
Old 07-27-2008, 04:51 PM
jf30cp's Avatar
mine did the same thing. check for burrs on the carb slide. make sure the clip is strait and not tilted. make sure you have the carb spring in there....... i think mine had a small burr that i couldnt see but when i ran the bike for like 5 min i think the fule lubed things up.
Big Boss Hoss
My "happy time" engine is so damn happy I heard it giggle at me today
Old 07-27-2008, 06:31 PM
VENICE BOY's Avatar
Custom Builder / Dealer
You posted this same question in two different places... you can read my advice on the other post.
Old 07-28-2008, 06:16 PM
Norman's Avatar
LORD VADER Moderator
your throttle cable looks to be snaked around the frame etc. that will cause the thing to bind another thing that will cause binding is the twist grip dragging on the handlebars and the handgrip itself dragging on the twist grip housing.
Looking again at your pictures your clutch cable is gong to be a pain in the rear as you have it wound up on the frame. Don't forget to get the brake cables installed before you blast off.
Best not to wrap the control cables on your frame.
norms-iron-works.tripod.com
Old 07-29-2008, 08:16 PM
Motorized Bicycle Apprentice
I dont know if I'd run that spark plug cable so tight.
Old 07-29-2008, 09:03 PM
Saddletramp1200's Avatar
There all right. Cables that have very low friction because of bends work much better than cables with kinks and curves. Nice bike, good job.
No matter where you go, or what you do, there Ya' are!
Advertisers
