need help in getting more top end speed
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. hi i have a 80cc, yeah i know 69cc, motor , i have moded the exhust byb putting on an expansion ...
Old 07-05-2009, 08:30 AM
Default need help in getting more top end speed
hi i have a 80cc, yeah i know 69cc, motor , i have moded the exhust byb putting on an expansion chamber, runs very well , awesome power , goes up any hill no prob no peddling, but around 35kmph it seems to lack power and kind of wants to stall its self at around that speed. with the stock muffler i could get to faster speeds but less power.
i was wondering if it might be a carb isue, do i need a bigger one??/ or do i need a larger jet hole to get more fuel in there???
can anyone help.....
Old 07-05-2009, 09:19 AM
Pablo's Avatar
Default Re: need help in getting more top end speed
What does the plug look like after a hard run? (for that matter, what plug and wire?)
What gears are you running?
Old 07-13-2009, 12:54 AM
Nashville Kat's Avatar
Usually the problem- reported all the time- seems to be too rich- to much gas to oil-
Does the slightest chocking kill the motor?
Close the petcock down by degrees- you may notice it runs better then-
too rich
most everyone here, myself included- usually thinks not getting enough gas at first
close the petcock down all the time, or mix in more oil, probably the better solution- and motor will probably last longer-
I drilled about five holes in the back of my air filter which helped a lot, more air to gas- leaningit down when it really gets flowing
s smaller rear sprocket like the 36 I installed really helps, because the motor has always run better under load, and now cruises faster
Narrower tires are the old bike racer trick- smoother tires roll much better than knobby too.
keep things lightweight- especially rotating weight- wheels, crank, chain- we used to say when racing that an ounce off the wheels was worth two off the frame
a bigger wheel is like putting on a slightly bigger gear- 27" or 700C is about four percentage up from 26" when you multiply it roughly by four to get 100 percent-
so a motor turning the rear sprocket the same rPMs will move the bike 4 percent faster with the larger wheel- 25 mph would then be increased by one mph, to 26 mph,
and greater then as the speed goes up- not as much difference as changing sprockets, but some- and the rolling resistence of a 1'1/4 inch tire is sooo much less than a 2.25" cruiser tire- if you don't mind the risk
Old 07-13-2009, 07:55 AM
Bikeguy Joe's Avatar
First determine if it's lean or rich. Most of the time with an expansion chamber, you will need to "upjet" or go to a richer jet.
